Does RichViewEdit support SVG files?
Doesn't seem to, any plans to?
Re: Does RichViewEdit support SVG files?
TRichView does not have a built-in support of SVG files, except for special code for saving and loading in DocX.
However, in VCL/LCL version you can use third-party implementation (inherited from TGraphic).
FMX version currently supports only raster graphic formats.
If you use DevExpress components, you can compile your project with the compiler $define RVUSEDXPNGIMAGE.
But there are other third-party SVG implementations.
Thanks, I do use DevExpress, will try that.
