TRichViewEdit. Modify bold only
cointec
Post by cointec »
I have a TRichViewEdit control and I retrieve the rich text through a TStringStream.
var lRTF: TStringStream;
lRTF := TStringStream.Create('');
Editor.SaveRTFToStream( lRTF, False );
Result := lRTF.DataString;
lRTF.Free;
If I only make the text bold, the text is not modified.
Another example, modifying only the size of a table.
Is there any TRichViewEdit option to apply those modifications?
a greeting
Re: TRichViewEdit. Modify bold only
Sorry, I do not understand the question.
Of course, there are many operations for modifying properties of font, paragraphs and objects that do not affect text content.
However, if you save text as RTF, RTF will be different because RTF is not just a plain text, it contains information about text and table properties.
I do not understand, how do you want to apply these changes?
In Editor? or in the resulting RTF string?
cointec
Post by cointec »
I edit a text
Set as bold text
When i save RTF text into TStringStream, the text is not modified:
function TfEditorRV.TextoRTF: string;
      lRTF.Free;
Editor is TRichViewEdit
If i set as bold text and add a new character its ok. Like this
Sorry, what do you mean?
Where is the text not modified? in Editor? In RTF string?
cointec
Post by cointec »
1. I put the original text in Editor.
2. With the Editor, I only put the text in bold
3. Using the method SaveRTFToStream( TStringStream, Boolean) from Editor. The text recovered have the origal texto
      lRTF.Free;
"lRTF.DataString" has the original text
If in addition to making the text bold, I add a character, the RTF text contain the change to bold
Do you mean that RTF saved at step 3 has non-bold text?
Can you create a simple project to reproduce this problem?
standay
Post by standay »
I tried this and it seems to be working. I'm changing the bold this way:
procedure TForm1.ToggleBold;
  if rve.GetItemStyle(rve.CurItemNo) <> 1 then
    rve.ApplyTextStyle(1)
    rve.ApplyTextStyle(0);
  rve.Reformat;
Then, using your function:
function TextoRTF: string;
      form1.rve.SaveRTFToStream( lRTF, False );
      lRTF.Free;
And this on a button:
procedure TForm1.Button4Click(Sender: TObject);
  ShowMessage(TextoRTF);
The RTF code returned by the TexttoRTF function is correct as I set or unset bold and click the button that runs the function. When I set the text to bold I see \b in the returned RTF. When I unbold it, the \b goes away in the returned RTF.
So, is the problem solved?
standay
Post by standay »
Sergey Tkachenko wrote: Mon Apr 11, 2022 4:48 pm So, is the problem solved?
My post above was just some test code to try and help the original poster. Not sure if what I tried will help him or not. Stan
cointec
Post by cointec »
My mistake, it works fine.
Sorry
