Overwrite Ctrl+Z
JPR
Overwrite Ctrl+Z
Post by JPR »
I would like to overwrite Ctrl+Z in TRichViewEdit but If I use KeyDown in delphi my code doesn't work correctly.
procedure TForm1.xre1KeyDown(Sender: TObject; var Key: Word;
  Shift: TShiftState);
  if (Key = 90) and (ssCtrl in Shift) then
    if MyUndoIdt < 1 then
      MyUndoIdt:= MyDim;
    if MyUndo[MyUndoIdt] <> nil then
      SendMessage(xre1.Handle, WM_SETREDRAW, 0, 0);
      xre1.LoadFromStream(MyUndo[MyUndoIdt], rvynaAuto);
      xre1.Format;
      FreeAndNil(MyUndo[MyUndoIdt]);
      xre1.SelStart:= MyUndoPos[MyUndoIdt];
      MyUndoPos[MyUndoIdt]:= 0;
      SendMessage(xre1.Handle, WM_SETREDRAW, 1, 0);
      xre1.Invalidate;
      Dec(MyUndoIdt);
    end
I need to do that to do a my proper undo because I use MarkString function. With this function Undo (RichView) doesn't work correctly.
Thank to help me.
JP
1) To disable the standard Ctrl+Z processing, assign Key:=0 in OnKeyDown
2) This code will crash TRichViewEdit if the caret is in table cell inplace editor. Use PostMessage to avoid this problem. Examples:
http://www.trichview.com/support/trichv ... tion_4.htm
http://www.trichview.com/support/trichv ... ream_4.htm
http://www.trichview.com/support/trichv ... brve_6.htm
JPR
Post by JPR »
Hello Sergey,
I would like not to disable but overwrite
Thank
JPR
May be it would be better to use undoable version of sting marking procedure? (SearchText + ApplyStyleConversion)
It's slower, but can be undone without tricks.
JPR
Post by JPR »
I have already try this method but I need a fastly Highligthing SQL script.
with MarkString function, I reduce by 3, time of process.
Have you a solution to overwrite Ctrl+Z, please Sergey ?
Because I try a lot of thing, but I don't find solution.
Thank
Michel
Post by Michel »
You could try catching it in Form.OnShortCut and setting Handled to True.
HTH,
Michel
And your code in OnKeyDown is not working? What's wrong with it?
Yes, it does not block the default processing of Ctrl+Z, but the default undo code will be executed after your code. After loading a file, an undo buffer is empty, so the default procedure should do nothing.
There will be a problem inside tables, as I mentioned before, but without tables it should work.
JPR
Post by JPR »
Hi sergey,
No this code doesn't work correctly. I have put a breakpoint on this procedure and Delphi can't execute this part of code.
Key = 90 not work.
I have put UndoLimit = 0
Thank
JP
Well, you are right, undo and redo keys are processed without calling OnKeyDown. I agree, it's not good.
The beginning of TCustomRichViewEdit.KeyDown must be changed from
  TRVEditRVData(RVData).PrepareForEdit;
  if (Key=VK_RETURN) and (rvoDoNotWantReturns in EditorOptions) then
    Key := 0;
  if IsUndoShortcut(Shift, Key) then begin
    Undo;
    Key := 0;
    end
  else if IsRedoShortcut(Shift, Key) then begin
    Redo;
    Key := 0;
  if Key = 0 then
  inherited KeyDown(Key, Shift);
to
  if (Key=VK_RETURN) and (rvoDoNotWantReturns in EditorOptions) then begin
    Key := 0;
  if Key = 0 then
    Undo;
    Key := 0;
    end
    Redo;
    Key := 0;
JPR
Post by JPR »
Thank Sergey but In what unit ?
JPR
RVEdit.pas
