How to make a particular line to topmost?
How can I make the line where the cursor is, to the topmost of a TRichViewEdit?
Re: How to make a particular line to topmost?
I tried this and it seems to work:
procedure ScrollItemToTop(rve: TCustomRichViewEdit);
DItem, DOffs: integer;
rve.RVData.Item2DrawItem(rve.CurItemNo, rve.OffsetInCurItem, DItem, DOffs );
rve.ScrollToDrawItem( rve.RVData, DItem, false, false );
rve.SetFocusSilent;
Yes, this is almost a correct solution. To support caret in table cells:
It has two small problems:
- it scrolls to the top of the item containing the caret, not to the top of the line (the difference is noticeable if the line has items that are taller than this item
- if a line is wrapped, and not on a space character, the position at the end of this line and at the beginning of the next line has the same (rve.CurItemNo, rve.OffsetInCurItem).
These problems are small, so you can use this solution.
A perfect solution requires undocumented methods, see my next post.
tle: TCustomRichViewEdit;
tle := rve.TopLevelEditor;
tle.RVData.Item2DrawItem(tle.CurItemNo, tle.OffsetInCurItem, DItem, DOffs );
rve.ScrollToDrawItem( tle.RVData, DItem, false, false );
rve.SetFocusSilent;
How to scroll to the top of the current line.
How to call:
uses CRVFData, RVERVData, DLines, RVCoords;
// Returns a range of drawing items on the RVData's line containing
// the DItemNo-th drawing item
procedure GetDItemsInLine(RVData: TCustomRVFormattedData;
DItemNo: Integer; out DItemNo1, DItemNo2: Integer);
DItemNo1 := DItemNo;
while not RVData.DrawItems[DItemNo1].FromNewLine do
dec(DItemNo1);
DItemNo2 := DItemNo + 1;
while (DItemNo2 < RVData.DrawItems.Count) and
not RVData.DrawItems[DItemNo2].FromNewLine do
inc(DItemNo2);
dec(DItemNo2);
// Returns the top coordinate of the RVData's line containing
// the DItemNo-th drawing item, relative to the top corner of the rv's document.
function GetLineTop(rv: TCustomRichView; RVData: TCustomRVFormattedData;
DItemNo: Integer): TRVCoord;
i, DItemNo1, DItemNo2: Integer;
R: TRVCoordRect;
function GetDrawItemCoords(Index: Integer): TRVCoordRect;
DItem: TRVDrawLineInfo;
DItem := RVData.DrawItems[Index];
Result := RVCoordBounds(DItem.Left, RVData.GetTransformedDItemTop(Index),
DItem.Width, DItem.Height);
GetDItemsInLine(RVData, DItemNo, DItemNo1, DItemNo2);
R := GetDrawItemCoords(DItemNo);
for i := DItemNo1 + 1 to DItemNo2 do
UnionRect(R, R, GetDrawItemCoords(i));
RVData.RotateRectFromDocToScreen(R, rvtrbAbsRoot);
Result := R.Top;
Y: TRVCoord;
Y := GetLineTop(RichViewEdit1, RichViewEdit1.TopLevelEditor.RVData,
TRVEditRVData(RichViewEdit1.TopLevelEditor.RVData).CaretDrawItemNo);
RichViewEdit1.ScrollTo(Y);
Your code can be modified to avoid this problem:if a line is wrapped, and not on a space character, the position at the end of this line and at the beginning of the next line has the same (rve.CurItemNo, rve.OffsetInCurItem).
uses RVERVData;
DItem: integer;
DItem := TRVEditRVData(tle.RVData).CaretDrawItemNo;
rve.SetFocusSilent;
I had forgotten about tables again. I'm not implementing them as such in my app but I do like to account for them in case I copy and paste one or more tables into my rve.
I hadn't gotten quite as far as using CaretDrawItemNo but yes, that's the better way! I would have probably gotten to that eventually.
I wasn't the original poster for this but I'd been wanting to figure it out at some point so seeing this got me thinking about it again.
Thanks Sergey, great info.
