How to export OLE objects from TRichViewEdit to a .rtf file.
anup sarda
Post by anup sarda »
In my application user is allowed to embed OLE objects in the TDBRichViewEdit. When the contents of the RichViewEdit are saved using SaveRTF function to a file the embeded OLE object is lost.
What should be done to save the embed OLE object in RTF file?
Thanks,
Anup
DavidRM
Post by DavidRM »
I had posted a long-ish answer to this question some time back. Unfortunately, that was on the newsgroup.
Before I dig it up, one question: Are you handling the OLE objects in TOleContainers embedded in the TRVE? That's how I do it, and my code is based on that assumption.
-David
DavidRM
Post by DavidRM »
Here is my code for exporting OLE objects in TOleContainers from TRVE to RTF. Most of the code is an event handler for OnSaveComponentToFile. Following that are some support routines for TOleContainer that are called in the handler.
There are some "magic numbers" in the output, but I've run into no issues when testing MS Word, Excel, and Visio on XP SP2 with Office 2002. If anyone has further information about the RTF format details, I'd be happy to hear them.
This code is used in my The Journal product.
Enjoy.
-David
http://www.davidrm.com/
procedure TJ4RVEStandardEventHandler.StandardSaveComponentToFile(Sender:TCustomRichView;
Path:String; SaveMe:TPersistent; SaveFormat:TRVSaveFormat; var
OutStr:String);
   function GetTwipsPerPixel:double;
         DC: HDC;
      DC:=CreateCompatibleDC(0);
         if RichViewPixelsPerInch>0 then
            Result:=(72*20)/RichViewPixelsPerInch
            Result:=(72*20)/GetDeviceCaps(DC,LOGPIXELSY);
         DeleteDC(DC);
      end; // try
   function GetLEIntHexStr(int:integer):string;
         ii: integer;
         bb: byte;
      // create "little endian" hexadecimal format
      Result:='';
      for ii:=1 to 4 do
         bb:=int and $FF;
         Result:=Result+IntToHex(bb,2);
         int:=int shr 8;
   function GetASCIIHexStr(const str:string):string;
         ss: integer;
      // creates hexadecimal list from string's characters
      Result:='';
      for ss:=1 to Length(str) do
         Result:=Result+IntToHex(Ord(str[ss]),2);
      Result:=Result+'00';
   function GetStreamHexStr(stream:TStream):string;
         ss, ssStop, cc: integer;
         bb: byte;
      // broken into 78-char lines, like TRichEdit's RTF embedded object output
      Result:='';
      ssStop:=(stream.Size-stream.Position) div 39;
      for ss:=1 to ssStop do
         for cc:=1 to 39 do
            stream.Read(bb,1);
         Result:=Result+#13#10;
      ssStop:=(stream.Size-stream.Position) mod 39;
         stream.Read(bb,1);
      if Result<>'' then
   const
      MetaPictName: string = 'METAFILEPICT';
      gif: TGifImage;
      imageFileName, className: string;
      sStream: TStringStream;
      mStream: TMemoryStream;
      ii: integer;
      metaFile: TMetafile;
   case SaveFormat of
      rvsfHTML:
         if SaveMe is TImage then
            gif:=TGifImage.Create;
               gif.Assign(TImage(SaveMe).Picture.Graphic);
               imageFileName:=Sender.SavePicture(SaveFormat,Path,gif);
               OutStr:='<IMG SRC="'+imageFileName+'">';
               gif.Free;
            end; // try
      rvsfRTF:
            sStream:=TStringStream.Create('');
               RVSaveImageToRTF(sStream,GetTwipsPerPixel,TImage(SaveMe).Picture.Graphic,
                                TImage(SaveMe).Width,TImage(SaveMe).Height,Sender.RTFOptions);
               OutStr:=sStream.DataString;
               sStream.Free;
            end; // try
            end
         else if (SaveMe is TOleContainer) and
(TOleContainer(SaveMe).OleObjectInterface<>nil) then
            className:=TOleContainer(SaveME).OleClassName;
               // write data
               sStream.WriteString('{\object\objemb');
               sStream.WriteString('{\*\objclass '+className+'}');
               ii:=Round(TOleContainer(SaveME).Width*GetTwipsPerPixel);
               sStream.WriteString('\objw'+inttostr(ii));
               ii:=Round(TOleContainer(SaveME).Height*GetTwipsPerPixel);
               sStream.WriteString('\objh'+inttostr(ii));
               sStream.WriteString('{\*\objdata'+#13#10);
               sStream.WriteString('01050000'#13#10);
               sStream.WriteString('02000000'#13#10);
               sStream.WriteString(GetLEIntHexStr(Length(className)+1)+#13#10);
               sStream.WriteString(GetASCIIHexStr(className)+#13#10);
               sStream.WriteString('00000000'#13#10);
               mStream:=TMemoryStream.Create;
                  SaveOleObjectAsDocumentToStream(TOleContainer(SaveMe),mStream);
                  mStream.Seek(0,0);
                  sStream.WriteString(GetLEIntHexStr(mStream.Size)+#13#10);
                  sStream.WriteString(GetStreamHexStr(mStream));
                  mStream.Free;
               end; // try
               // write metapict
               sStream.WriteString('05000000'#13#10);
               sStream.WriteString(GetLEIntHexStr(Length(MetaPictName)+1)+#13#10);
               sStream.WriteString(GetASCIIHexStr(MetaPictName)+#13#10);
               metaFile:=TMetafile.Create;
                  metaFile.Handle:=GetOleObjectMetaPict(TOleContainer(SaveMe));
                  ii:=Round(metaFile.Width*GetTwipsPerPixel);
                  sStream.WriteString(GetLEIntHexStr(ii)+#13#10);
                  ii:=-Round(metaFile.Height*GetTwipsPerPixel);
                     metaFile.Enhanced:=false;
                     metaFile.SaveToStream(mStream);
                     mStream.Seek(22,0); // sizeof(TMetafileHeader)=22
                     sStream.WriteString(GetLEIntHexStr((mStream.Size-22)+8)+#13#10);
                     ii:=(ii shl 16) or $0008;
                     sStream.WriteString(GetLEIntHexStr(ii));
                     ii:=Round(metaFile.Height*GetTwipsPerPixel);
                     sStream.WriteString('}');
                     // write "result" (metapict again)
                     sStream.WriteString('{\result');
                     sStream.WriteString('{\pict\wmetafile8');
                     sStream.WriteString('\picw'+inttostr(ii));
                     sStream.WriteString('\pich'+inttostr(ii));
                     sStream.WriteString('\picwgoal'+inttostr(ii));
                     sStream.WriteString('\pichgoal'+inttostr(ii)+#13#10);
                     sStream.WriteString('}}');
                     mStream.Free;
                  end; // try
                  metaFile.Free;
               end; // try
               sStream.Free;
            end; // try
      end; // case
procedure SaveOleObjectAsDocumentToStream(OleContainer:TOleContainer;
Stream:TStream);
      PersistStorage: IPersistStorage;
      TempLockBytes: ILockBytes;
      TempStorage: IStorage;
      DataHandle: HGlobal;
      BufferSize: integer;
      Buffer: Pointer;
   if OleContainer.OleObjectInterface<>nil then
      OleContainer.OleObjectInterface.QueryInterface(IPersistStorage,PersistStorage);
      if PersistStorage<>nil then
         OleCheck(CreateILockBytesOnHGlobal(0,True,TempLockBytes));
         OleCheck(StgCreateDocfileOnILockBytes(TempLockBytes,STGM_READWRITE
               or STGM_SHARE_EXCLUSIVE or STGM_CREATE,0,TempStorage));
         OleCheck(OleSave(PersistStorage,TempStorage,False));
         PersistStorage.SaveCompleted(nil);
         OleCheck(GetHGlobalFromILockBytes(TempLockBytes,DataHandle));
         BufferSize:=GlobalSize(DataHandle);
         Buffer:=GlobalLock(DataHandle);
            Stream.WriteBuffer(Buffer^,BufferSize);
            GlobalUnlock(DataHandle);
         end; // try
function GetOleObjectMetaPict(OleContainer:TOleContainer):HGlobal;
      DataObject: IDataObject;
      FormatEtc: TFormatEtc;
      Medium: TStgMedium;
      ClassID: TCLSID;
   Result:=0;
      // metapict won't draw unless the object's server is running
      if OleContainer.State=osLoaded then
         OleContainer.Run;
      OleContainer.OleObjectInterface.QueryInterface(IDataObject,
DataObject);
      if DataObject<>nil then
         if OleContainer.Iconic then
            FormatEtc.cfFormat:=CF_ENHMETAFILE;
            FormatEtc.ptd:=nil;
            FormatEtc.dwAspect:=DVASPECT_ICON;
            FormatEtc.lIndex:=-1;
            FormatEtc.tymed:=TYMED_ENHMF;
            if Succeeded(DataObject.GetData(FormatEtc,Medium)) then
               Result:=Medium.hEnhMetaFile;
            end
            OleContainer.OleObjectInterface.QueryInterface(IDataObject,DataObject);
            if DataObject <> nil then
               FormatEtc.ptd:=nil;
               FormatEtc.dwAspect:=DVASPECT_CONTENT;
               FillChar(Medium,SizeOf(Medium),0);
               if Succeeded(DataObject.GetData(FormatEtc, Medium)) then
Thank you, David.
I added a link to this topic in the Examples&Demos forum
Guest
Post by Guest »
Thanks David,
I tried using the code. It complied but the result is not as expected. I could see one image (rectangle with diagonal lines) instead of OLE object. It behaves as an image and not OLE.
While debugging I found that the following statment from GetOleObjectMetaPict is failing
I don't know what is the reason for the failure of this statement. Can you please help.
One more question...
How canl I import this OLE back to TDBRichViewEdit from the .rtf file?
Thanks,
Anup
DavidRM
Post by DavidRM »
Anonymous wrote:I tried using the code. It complied but the result is not as expected. I could see one image (rectangle with diagonal lines) instead of OLE object. It behaves as an image and not OLE.
Without more information about the OLE object in question, it's hard to say. Are you certain that the OLE server supprts creating the metapict?
My testing was done with standard OLE servers like MS Word, Excel, Visio, etc.
Anonymous wrote:One more question...
That's a bit harder to share. It boils down to this:
1. You need a TRichEdit component (like TRxRichEdit) that supports embedded objects.
2. You then load the RTF file into this component, and use the IRichEditOle interface to cycle through all of the objects (if any).
3. As you cycle through the objects, you can load the RTF *between* the objects into the TRVE. When you find an object, you load it into a TOleContainer, and insert that component into the TRVE.
Hope that helps.
-David
MLefebvre
Post by MLefebvre »
Hi, David
I have tried your code to save a RV-embedded object (via TOleContainer) to RTF, and this works fine. (note that one must "use" ActiveX, ComObj and RVFuncs to compile ok).
Yet there is a problem with the visual size of the result in RTF : when opened with MS-Word (2000), it seems about 60% of the size of the original object in RV. In addition, does not seem to take into account any resizing done from within RV.
Would you have any idea about this ?
Thanks in advance
ML
DavidRM
Post by DavidRM »
ML,
It could be that the calculation of the metafile's width and height should ignore the RichViewPixelsPerInch and just use the device context PPI. You could experiment with that and see if it makes any difference.
I'm not sure I'll have a chance to experiment with it soon, but I'll try to work it in.
-David
MLefebvre
Post by MLefebvre »
Well, actually I work with the default value for RichViewPixelsPerInch (=0), so it should make no difference.
It might be depending on the way the resizing is handled within RV. In my case I just let RV do the job, by allowing the RV item to be resized and setting the sizemode of the TOleContainer to smScale (to keep proportions in all circumstances). But to be honnest I did not understand all of it.
I am neither a specialist of RTF nor of Metafiles. I can see in your code that there are many places where "width" and "height" are specified, but I do not know their roles and priorities. I am afraid I could spend years trying all possible combinations ...
To summarize, as soon as you have a brilliant idea on this, I'll be happy if you can let me know. Thanks in advance.
Michel
I created a unit based on your code:
http://www.trichview.com/forums/viewtop ... 3569#13569
I made some optimization, checked Delphi 2009-2010 compatibility, and changed a way for getting a metafile.
Unfortunately, requesting a metafile from OleContainer is not reliable, it fails, for example, for Paint pictures or embedded files (displayed as an icon). And an invalid metafile makes Word to ignore the whole object. So I just used OleContainer.PaintTo procedure. Alternatively, a metafile can be specified as a parameter.
DavidRM
Post by DavidRM »
Very cool. I'll check it out.
-David
