Issues extracting text from RTF with TRichview 20
Alexander_Dober
Post by Alexander_Dober »
I've installed the trial version of TRichView 20 and can't compile my project because of some issues with some helper functions, that were created with your help some time ago:
type
   TRTFConverter = class(TObject)
      private
         FParser: TRVRTFReader;
         FFirstLine: Boolean;
         FRTFText: TRVUnicodeString;
         FStream: TStream;
         procedure DoReaderText(Sender: TRVRTFReader; const Text: TRVAnsiString; Position: TRVRTFPosition);
         procedure DoReaderUnicodeText(Sender: TRVRTFReader; const Text: TRVUnicodeString; Position: TRVRTFPosition);
   	public
         constructor Create;
         destructor Destroy; override;
         function ExtractTextFromRTF(RTFContent: string): string;
procedure TRTFConverter.DoReaderText(Sender: TRVRTFReader; const Text: TRVAnsiString;
   TextW: TRVUnicodeString;
   CodePage: Cardinal;
   if (Position <> rtf_ts_ContinuePara) and not FFirstLine then begin
      FRTFText := FRTFText + #13#10;
   FFirstLine := False;
   if Sender.FontTable.Count = 0 then begin
      CodePage := CP_ACP;
   end
   else begin
      CodePage := RVU_Charset2CodePage(Sender.FontTable[Sender.RTFState.CharProps.FontIndex].Charset);
   TextW := RVU_RawUnicodeToWideString(RVU_AnsiToUnicode(CodePage, Text));
   FRTFText := FRTFText + TextW;
procedure TRTFConverter.DoReaderUnicodeText(Sender: TRVRTFReader; const Text: TRVUnicodeString;
   FRTFText := FRTFText + Text;
function TRTFConverter.ExtractTextFromRTF(RTFContent: string): string;
   lList: TStringList;
   lBlobStream: TMemoryStream;
   FRTFText := '';
   FFirstLine := True;
   FParser := TRVRTFReader.Create(nil);
   lList := TStringList.Create;
   lBlobStream := TMemoryStream.Create;
      lList.Text := RTFContent;
      lList.SaveToStream(lBlobStream);
      lBlobStream.Position := 0;
      FParser.OnNewText := DoReaderText;				<- Incompatible Types: 'TCustomRVMSWordReader' und 'TRVRTFReader'
      FParser.OnNewUnicodeText := DoReaderUnicodeText;			<- Incompatible Types: 'TCustomRVMSWordReader' und 'TRVRTFReader'
      if FParser.ReadFromStream(lBlobStream) = rtf_ec_OK then begin	<- Incompatible Types
         Result := FRTFText;
      FreeAndNil(lBlobStream);
      FreeAndNil(lList);
      FParser.Free;
Can't find anything in the help file or in the announcement threads since version 18.0 (where it still worked).
Re: Issues extracting text from RTF with TRichview 20
Parameters of these events were changed when DocX import was implemented: DocX and RTF readers are inherited from the same class.
1) Change the declarations:
procedure DoReaderText(Sender: TCustomRVMSWordReader; const Text: TRVAnsiString; Position: TRVRTFPosition);
procedure DoReaderUnicodeText(Sender: TCustomRVMSWordReader; const Text: TRVUnicodeString; Position: TRVRTFPosition);
2) ReadFromStream now returns a boolean value (True: success; False: error)
Alexander_Dober
Thanks,
after changing the sender to TCustomRVMSWordReader this part still isn't working:
      CodePage := CP_ACP;
   end
   else begin
.FontTable and .RTFState don't exist here. What is supposed to be used here?
Typecast Sender to TRVRTFReader:
if TRVRTFReader(Sender).FontTable.Count = 0 then begin
One more thing, the call of RVU_RawUnicodeToWideString must be removed. I.e. instead of
must be
TextW := RVU_AnsiToUnicode(CodePage, Text);
You used the demo from this topic:
https://www.trichview.com/forums/viewtopic.php?t=2702
It was rather old, so I updated it for TRichView version 20 compatibility.
Now it supports not only RTF, but also DocX.
