Read Outlook files .msg
dagmarsawayn
Post by dagmarsawayn »
Does it's possible to read a .msg files extract from Outlook to a TRichView ?
If yes, how ? I'm searching but noting works :(
Thanks,
Re: Read Outlook files .msg
Sorry, TRichView cannot read Outlook files directly.
But I believe it is possible using Outlook COM object. This solution requires Outlook to be installed on the computer.
Is it ok? If yes, I can make a demo.
