Integration with DevExpress Ribbon VCL: styles and spelling checking
We've updated components for integration of TRichView and Developer Express VCL components.
Support of the recent version
Since this version, TRichView requires DevExpress VCL 21.2 or newer (because it contains a newly introduced IAccessible helper class).
If you still use an older version of DevExpress VCL, remove the define {$DEFINE DX_VER_21_2} from cxTRichView.pas
New controls for TdxRibbon
In the previous update of TRichView+DevExpress integration components, we introduced new controls and helper classes for DevExpress Ribbon.
In this update, we added a new control for the ribbon: TdxBarRVFStyleTemplateCombo. It displays a list of named styles of text and paragraphs.
This control is an analog of TRVStyleTemplateComboBox, which is based on a standard TComboBox. TdxBarRVFStyleTemplateCombo implements almost all its features (except for a mode of displaying only used and important styles).
Live spelling check
Since this update, TRVAdxRibbonPopupMenu supports live spelling checking.
https://www.trichview.com/forums/viewto ... =6&t=10515
