Having trouble opening:-
C:\Components\TRichView\TRichView\Demos\Delphi\DB Demo\1 DBRichViewEdit
similarly for this one as well
C:\Components\TRichView\TRichView\Demos\Delphi\DB Demo\2 RichViewEdit
C:\Components\TRichView\TRichView\Demos\Delphi\DB Demo\3 DBGrid
Class TTable not found ????
Any help is appreciated
Richard
Having Trouble opening DB Demos
Re: Having Trouble opening DB Demos
These demos use BDE (Borland Database Engine)
BDE is obsolete and is not supported by new versions of Delphi.
If you use a recent versions of Delphi, it's better to use demos not from "Delphi", but from "DelphiUnicode" folder.
Specifically, with FireDAC_IB extension in directory names.
These demos use FireDAC components, and InterBase tables (InterBase server must be running)
TRIED UNICODE PROJECT STILL NO LUCK
Connection definition parameters
User_Name=sysdba
Password=*****
Database=C:\Components\TRichView\TRichView\Demos\DelphiUnicode\DB Demos.FireDAC_IB\1 DBRichViewEdit\SAMPLETABLE.GDB
DriverID=IB
FireDAC info
Tool = RAD Studio 11.0
FireDAC = 28.0.0 (Build 106147)
Platform = Windows 32 bit
Defines = FireDAC_NOLOCALE_META;FireDAC_MONITOR
Client info
Loading driver IB ...
Brand = InterBase
Client version = 1402009900
Client DLL name = C:\Windows\SYSTEM32\gds32.dll
Session info
Failed to connect to DBMS !
[FireDAC][Phys][IB]unavailable database
User_Name=sysdba
Password=*****
DriverID=IB
FireDAC info
Client info
Brand = InterBase
Session info
- fdbDEMO ERROR MESSAGE.png (90.94 KiB) Viewed 25628 times
It seems
I have a licensing issue with IB RAD SERVER
and it is a new license.
One thing to check, if the running server and the connection has the same port.
If port is not specified in connection parameters, it is taken from the environment variable IB_PROTOCOL.
When Delphi is running, it may apply additional environment variables.
You can check them in Tools | Options, page IDE | Environment variables.
For example, it may define IB_PROTOCOL = developer_ib2020.
When you run IterBase Server Manager, check its caption. It should contain the same string in [], like [developer_ib2020].
It works now....Thanks
