TSRichViewEdit.SelectAll method behavior
Vitalii
Post by Vitalii »
I think that in the TSRichViewEdit.SelectAll method it is more logical to select the content of ActiveEditor instead of RichViewEdit. Because if you press CTRL+A while editing the header, then not the header is selected, but the main text.
Re: TSRichViewEdit.SelectAll method behavior
I agree.
This change will be included in the next update.
Vitalii
Post by Vitalii »
Ok, thanks!
