RVE Version Number
standay
RVE Version Number
Post by standay »
Is there some way to pull the version number of the rve component currently in use to display in my about box info? I can type it in but if there's a way to pull it "automatically" I'd like to do that.
Thanks Sergey.
Re: RVE Version Number
RVVersion constant in RVStr unit (or fmxRVStr in FireMonkey version)
standay
Post by standay »
Sergey Tkachenko wrote: Thu Sep 23, 2021 8:05 am RVVersion constant in RVStr unit (or fmxRVStr in FireMonkey version)
Perfect, thanks. I used several of your constants. You might consider adding an RVCopyright const too (I added that text in manually). Here's the about screen now:
