Spelling Exception?
standay
Spelling Exception?
Post by standay »
Sergey,
Is there a way to skip spell checking an item? Normally I want to check everything, but if I insert a snippet of code I'd like to be able to flag or mark that so the spell check will not show anything in it as misspelled.
Thanks Sergey
Re: Spelling Exception?
In the current version, all text items that have Charset <> SYMBOL_CHARSET are checked.
I'll implement spelling exceptions in one of future versions.
standay
Post by standay »
I was able to get it to work doing these things. Where I set the text styles I do:
    FontInfo := TFontInfo.Create(nil);
  for i := DItem1 to DItem2 do
    FontInfo.Assign(RVStyle1.TextStyles[ rve.GetItemStyle(i) ]);
    FontInfo.StyleName := 'nospell';
        NewStyleNo := RVStyle1.TextStyles.Count;
        RVStyle1.TextStyles.Add;
        RVStyle1.TextStyles[NewStyleNo].Assign(FontInfo);
        RVStyle1.TextStyles[NewStyleNo].Standard := False;
    rve.GetItem(i).StyleNo := NewStyleNo;
    FontInfo.Free;
And in SpellingCheck I used:
  if Spelling1.Checked and (RVStyle1.TextStyles[StyleNo].StyleName <> 'nospell') then
Spelling1 is a menu item I can set to turn spell check completely on or off.
I tried using basestyleno as the flag first (screen shot below) but that does not see to be saved when I save the file.
I may or may not keep this in my app for now. I'd be more comfortable with a solution you come up with in the future.
