Saving SelStart, SelLen and scroll positions
standay
Post by standay »
Sergey,
I am saving my RVF SelStart, SelLen and scroll positions in the file itself. I prefer that to using an external INI or XML file. Here's what I'm using:
    rve.SetItemExtraStrProperty(0, rvespTag,
      SelStart.ToString + ',' + SelLen.ToString + ',' +
        VScroll.ToString + ',' + HScroll.ToString ) ;
    rve.SaveRVF( EntryPath + FileName, false );
When I read it back, I use this:
    SelStart := 0;
    SelLen := 0;
    VScroll := 0;
    HScroll := 0;
    tempList:= TStringList.Create;
    rve.GetItemExtraStrProperty(0, rvespTag, temp );
    tempList.DelimitedText := temp;
    if tempList.Count = 4 then
      SelStart := StrToInt(tempList.Strings[0]);
      SelLen := StrToInt(tempList.Strings[1]);
      VScroll := StrToInt(tempList.Strings[2]);
      HScroll := StrToInt(tempList.Strings[3]);
This is actually working pretty well, and I'll do some additional error trapping later. But my questions now are:
  • Is there a built-in function somewhere that will do this that I've missed?
  • If not, is using GetItemExtraStrProperty(0, rvespTag, temp ) OK?
  • Will using GetItemExtraStrProperty on item 0 cause a problem if I added a regular tag to that item later?
Re: Saving SelStart, SelLen and scroll positions
As I understand, the question is how to store additional information with document in RVF format.
There are two ways to do it.
1) rve.DocProperties. This is a TStringList. It is saved and loaded in RVF if you include rvfoSaveDocProperties and rvfoLoadDocProperties in rve.RVFOptions.
DocProperties is a string list.
You can fill it as
rve.DocProperties.Values['SelStart'] := SelStart.ToString;
2) rve.DocObjects. This is a collection of items that may have different types, but must be inherited from TRVDocObject. It is saved and loaded in RVF if you include rvfoSaveDocObjects and rvfoLoadDocObjects in rve.RVFOptions.
The object may be define like this:
type
  TRVMyDocObject = class (TRVDocObject)
  private
    FSelStart, FSelLen, FVScroll: Integer;
  published
   property SelStart: Integer read FSelStart write FSelStart;
   property SelLen: Integer read FSelLen write FSelLen;
   property VScroll: Integer read FVScroll write FVScroll;
Before saving, check items of rve.DocObjects. If this collection contains item of TRVMyDocObject class, modify its properties.
If not, create a new object:
  MyDocObj: TRVMyDocObject;
MyDocObj := TRVMyDocObject.Create(rve.DocObjects);
and assign its properties.
After loading RVF, check items of rve.DocObjects, whether this collection contains item of TRVMyDocObject class.
standay
Post by standay »
Thanks Sergey, looks like doc properties should work. I'll try it soon.
Edit: Yes, the doc properties worked great. MUCH better than what I was doing. Thanks!
