Bug in RVGetTextLength function
JPR
Post by JPR »
Hello everybody,
I have a bug (I think in RVGetTextLength function)
If I do that, DELPHI send me Out of limit (-1)
MyRichViewEdit.Clear;
ShowMessage(IntToStr(RVGetTextLength(MyRichViewEdit)));
Have youa solution for that Sergey ?
Thank
JP
Michel
Post by Michel »
You need to call Format after Clear.
Well, yes, calling Format saves the situation for TRichViewEdit (because it adds one empty text item).
But not for TRichView, so it may be really considered as a bug.
Fix: open RVLinear.pas, change RVGetTextLength:
function RVGetTextLength(rv: TCustomRichView): Integer;
  Result := 0;
  if rv.ItemCount=0 then
  RichViewToLinear(rv, rv.RVData, rv.RVData, rv.ItemCount-1,
    rv.GetOffsAfterItem(rv.ItemCount-1), Result);
  if Result>0 then
    dec(Result);
