The current version of TRichView supports ReportBuilder 21. No changes in source code or installers are necessary.
However, if you used older version of ReportBuilder with TRichView, after installing ReportBuilder 21 you need to re-run TRichView setup (the shortcut "Install TRichView in Delphi IDE" does not do all necessary work, you need to re-run the full setup).
ReportBuilder changes names of its packages on each major update, and TRichView setup updates package references according to the detected version of ReportBuilder.
Previous version
viewtopic.php?t=9671
About ReportBuilder 21 support
