[TRichView bug?] Problem with white font and AddPicture
Jacek Puczynski
Post by Jacek Puczynski »
Hello. I foud some problems with inserting some text AFTER i call AddPictureEx, AddHotPicture or other method.
RichView->AddPictureEx(img, insertimg, -1, rvvaBaseline);
This problem affects only TRichView working at systems Windows 98 and Windows ME. At Windows XP TRichView works fine.
Problem description: When I insert some colored text in TRichView before Picture (TGIFImage) then text is in color from ParaStyle but when I insert text AFTER picture then text always change color to white (in ParaStyle is other color for this text).
Some screenshots from the same program working on Windows 98 and Windows XP:
Windows XP (text after image):
Windows 98 (text after image):
Windows XP (text before image):
Windows 98 (text before image):
More about this error: while I select some text and image on Windows 98, text in some cases is visible in right color:
Screens from Windows 98:
I will be thankful for any help with this.
Greetings, Jacek.
Jacek Puczynski
I've noticed this problem affects only for some GIFs (i think : non animated and transparent)
this is GIF I use on screens:
http://img480.imageshack.us/img480/7353/haha9xj.gif
Jacek Puczynski
More if I call:
GifImage->DrawOptions >> goTransparent;
before i insert it to TRichView it non transparment but font has right color.
Does this problem persist if you include RVGifAnimate.pas in the project, and change RV->AnimationMode to rvaniOnFormat?
Jacek Puczynski
Sergey Tkachenko wrote:Does this problem persist if you include RVGifAnimate.pas in the project, and change RV->AnimationMode to rvaniOnFormat?
Yes, it is. Screens are from program which has added RVGifAnimate.pas to project and AnimationMode sets to rvaniOnFormat.
Greetings, Jacek.
Please send me this document saved as RVF file.
Jacek Puczynski
Jacek Puczynski
Some news about this bug? :?
Please send this file me by e-mail ( [email protected] ).
Rapidshare is almost useless for me, because I have a common external IP with many users of my local network, so Rapidshare usually says me that my download limit is exceeded.
Jacek Puczynski
Confirmed.
Fix: in RVItem.pas, add the following lines
      if not RVNT then
        Canvas.Refresh;
in TRVGraphicItemInfo.Paint, after the lines
      if DCState<>0 then
        RestoreDC(Canvas.Handle, DCState);
