camera settings
labchara
camera settings
Post by labchara »
Hello
how can i modify camera settings (contrast, brightness ..) from RVcamera components?
Re: camera settings
It is possible only for local cameras, or several IP-camera models (the IP-camera must be found by SearchCamera).
The following properties are supported: Brightness, Contrast, Hue, Saturation, Sharpness.
To check if the current camera supports the given property, and to get the range of its values, use GetColorControlPropertyRange.
For local cameras, you can also use TRVWebCamDialog
labchara
Re: camera settings
Post by labchara »
Congratulations
