AppendRVFFromStream
AppendRVFFromStream
Greetings,
I need to use AppendRVFFromStream to append a footnote into a table.
It is working excellently in the regular text. But when I try to append into a table it places the footnote before the table. Ideas as to how to fix this?
Re: AppendRVFFromStream
Please post your code for appending to a table.
It is a modified version that I use in rvhtmlimport (I did a custom version)
Basically near the end: FViewer.AppendRVFFromStream(msRVE,-1);
//Inserting a footnote from Sergey's code
procedure TJGKRvHtmlImporter.CustomFootnoteInsert(ms: TMemoryStream);
FootNote: TRVFootnoteItemInfo;
NoteRef: TRVNoteReferenceItemInfo;
Crve: TRichViewEdit;
msRVE: TMemoryStream;
Crve := TRichViewEdit.Create(nil);
Crve.Style := TRVStyle.Create(nil);
Crve.Visible:= False;
Crve.Parent := FViewer;
Crve.Style := FViewer.Style;
Crve.Clear;
FootNote := TRVFootnoteItemInfo.CreateEx(Crve.RVData,
RVStyleFindFont('Segoe UI', clBlue, 10, [], rvsssSuperScript, False),
1, False);
NoteRef := TRVNoteReferenceItemInfo.CreateEx(FootNote.Document,
RVGetNoteTextStyleNo(FViewer.Style, 0));
FootNote.Document.AddItem('', NoteRef);
FootNote.Document.AddNL(' ', 0, -1);
FootNote.Document.LoadRVFFromStream(ms);
Crve.InsertItem('' ,FootNote);
Crve.Format;
msRVE := TMemoryStream.Create;
Crve.SaveRVFToStream(msRVE,False);
msRVE.Position := 0;
//Append footnote number into content
msRVE.Clear;
Crve.Free;
msRVE.Free;
But you append the document to the end of FViewer, not in a table.
If you need to append to a table cell, call Table.Cell[r,c].AppendRVFFromStream
PS: LoadRVFFromStream clears footnote document before loading, removing a note reference and a space character. AppendRVFFromStream would be useful here
PPS: Format is not needed after InsertItem. InsertItem is an editing method, it requires a formatted document before its call, and leaves the document formatted.
Ah thanks I'll have to see if there is someway I can get the table information it is in. Yes to the end of the FViewer wherever the converted html/xhtml is at at that time in rvhtmlimport. But perhaps I can get it to tell me if it is in a table. I will email you so it makes more sense
This is in rvhtmlimport so somethings are quite interesting if you remember that document.
In RvHtmlImporter, there is FRVData field that contains the current document. It may be the main document, or a cell (when reading table).
You do not need a temporal TRichViewEdit, you do not need AppendRVFFromStream.
Simply pass FRVData in the constructor of TRVFootnoteItemInfo, and add it using FRVData.AddItem method.
Thank you for your patience on this.
So I have an array of RichView streams: GTagRVFStrArray.ms_rv
I need to make them into a footnote and then add it.
I am sure there is a much better way to do this.
What I am doing at present is finding the data that needs put into footnotes. Saving it as a RichView that is put into a stream to keep formatting.
Then I find the pair of that data later on in a secondary loop through the overall content. Now I bring the data out of the string put it in a footnote format and add it.
Steps basically:
basically grab text with format > save to RV stream array > find it when we need it from the array > convert to Footnote > add/insert it correctly
Thanks for the help sir!
