Insert RTF from stream without line break
mikesm
Post by mikesm »
how do i insert rich text into richviewedit without inserting a new line at the end of the text. I use the InsertRTFFromStreamEd function, there is a new line after the inserted content.
DannyLe
Re: Insert RTF from stream without line break
Post by DannyLe »
Has there been any updates regrading this post? I believe I am running into the same issue.
Thank you
Current behavior: insert the ending line break when inserting RTF as an editing operation; ignore it overwise.
It is hard-coded.
If you want to change it, modify the line in RVRTFProps.pas:
from
    TRVRTFReader(Reader).ProcessFinalPar := EditFlag;
to
    TRVRTFReader(Reader).ProcessFinalPar := False;
