Hi, we have just updated to a newer version of TRichview/TScaleview.
Almost everything worked without a problem but got stuck when trying to convert RVA_ConvertToTwips(Self);
Any ideas how to best replace the procedure?
unit RichViewActions;
procedure RVA_ConvertToTwips(Form: TComponent);
i: Integer;
for i := 0 to Form.ComponentCount - 1 do
if Form.Components is TrvCustomAction then
TrvCustomAction(Form.Components).ConvertToTwips;
Regards
Daniel
Convert old function RVA_ConvertToTwips
Re: Convert old function RVA_ConvertToTwips
This function still exists, but it has additional TRVStyle parameter.
For TSRichViewEdit, call
RVA_ConvertToTwips(Self, SRichViewEdit1.RichViewEdit.Style);
And consider using EMU instead. All new RichViewActions demos were switched from twips to EMU.
Read more about twips and EMU here: https://www.trichview.com/help/idh_type ... units.html
Will have a look.
Now it is working. Thanks for help.
