TRichViewEdit as a single line edit box
JLuckey
Post by JLuckey »
I'm using a TRichViewEdit (ver 1.9.15) as a single-line edit box and preventing word wrap w/ the following code:
for i := 0 to RVStyle1.ParaStyles.Count-1 do
RVStyle1.ParaStyles.Options := RVStyle1.ParaStyles.Options+[rvpaoNoWrap];
RichView1.Reformat;
(which works great)
However I am able to scroll the text in the box vertically about one-half of a line using the up and down arrow keys.
How do I prevent this vertical strolling?
Thanks!
Set RichViewEdit.VSmallStep := 1 (before calling Format)
JLuckey
Post by JLuckey »
That's a little better.
Now instead of moving one-half of a line, the text only moves a small distance when I use the up/dn arrow keys. I tried setting VSmallStep := 0 (didn't work).
Do you have any other suggestions? Should I trap for the arrow keys & disabale them?
thanks..
Yes, you can use OnKeyDown to disable Up and Down keys.
Also, set WheelStep property = 0.
MLefebvre
Post by MLefebvre »
FYI : I have been fighting this (small) problem for hours ... Finally found 2 ideas, maybe one of them is suffcient :
- Setting RV.ClientHeight to DocumentHeight+VSmallStep+1
- Adding RV.ScrollTo(0) in various events (key handler, OnChange). In your case, maybe you could use the OnCaretGetOut event.
JLuckey
Post by JLuckey »
Trapping for the Down Arrow key in onKeyDown does the trick. I haven't tried setting ClientHeight.
Thanks for the suggestions...
