What manual things can we do without actions in ScaleRichView?
justinalaniz
Post by justinalaniz »
Spectra Precision LT20G: Best Rated Self-Leveling Laser Level
Do you want to make your leveling job easier by owning a top-rated laser level? Consider your search is over because the Spectra Precision LT20G cross line laser level includes advanced features to make your tasks a breeze.
Spectra Precision LT20G Laser Level: Brief Introduction
Spectra Precision LT20G projects horizontal and vertical lines for versatile uses. We found it the best laser level because it has a wide laser beam fan angle that delivers maximum coverage around the unit.
You can rely on it to execute many applications accurately, including installing kitchen cabinets, stair rails, tiles, etc. It will generate accurate layouts to find vertical plumb, leveling, and alignment points on uneven and large surfaces.
☞☞☞ See Also: Which Are The Best Laser Level Brands on The Market Image
Is Spectra Precision LT20G Laser Level Really Worth It?
Let us discuss the top features making Spectra Precision LT20G laser level a worth investment tool.
◆ Robust & Rugged Design
The sturdy and generous over-mold housing of the Spectra Precision LT20G makes it an ideal laser level to use in harsh conditions. This laser leveling device is highly durable because of its superior construction. Its cross lines provide perfect layouts for many square applications.
◆ Automatic Leveling System
If you often have to deal with leveling projects, you must buy Spectra Precision LT20G laser level. Why? Because it includes an automatic leveling system that sets the unit right after placing it on a flat surface or a tripod, making it the best laser level for new users.
◆ Box Includes All Accessories
The Spectra Precision LT20G is not only affordable laser level but also comes with a variety of attachments. You will get it with a soft pouch, target, mounting strap, magnetic mounting bracket, and batteries. If you don't know how to use this product, the user guide will thoroughly guide you.
❖❖❖ Useful Link: Best Laser Level - The Most Accurate Laser Levels in The World Image
◆ Powerful Batteries
Spectra Precision LT20G comes with 4 AA batteries. Hence, you can start using this laser level right after opening the box. Because of the robust batteries, this product can run without interruption for a long time.
◆ Maximum Coverage
Spectra Precision LT20G is best suited for projects that require extreme precision, such as installing a pipeline system or any electrical cables in a structure. As mentioned above, it includes a wide fan angle for maximum coverage and enhanced convenience. So, consider it the best rated laser level for your upcoming projects.
◆ Lightweight
Do you know why professionals love lightweight laser levels? Of course, carrying a bulkier laser level becomes challenging for users. The Spectra Precision LT20G is designed to be exceptionally easy to carry, thanks to its weight of 0.8 ounces.
❖❖❖ You Might Also Enjoy: Top Rated Laser Levels You Should Buy Image
Conclusion
Due to its capability to execute various indoor and outdoor applications, Spectra Precision LT20G laser is ideal for both professionals and homeowners. We also found it a perfect tool for surveyors, engineers, builders, carpenters, and everyone who wants accurate and quick leveling layouts. Undeniably, this fantastic device can make your job more enjoyable.
Re: What manual things can we do without actions in ScaleRichView?
Without actions, you can do all the things that you can do with actions, but it requires more code.
Basic actionless editors can be found in <TRichView Dir>\Demos\RVDemos\Editors\ folder.
Or do you mean what you can do if you just place TSRichViewEdit on a form, without writing any code?
Without writing any code, the user can:
- type text,
- delete content,
- copy and paste,
- drag&drop from and to the editor
- switch between the main document, the header and the footer (double click)
- change zoom (mouse wheel)
