TdbRichViewEdit cursor position
jota
Post by jota »
Hi
Can somebody help me?
How can you detect that the cursor is positioned on the first character of a line (with or without a bullet)?
Thanks in advance
Re: TdbRichViewEdit cursor position
Do you mean paragraph?
If yes, the code is
function IsAtTheBeginningOfParagraph(rve: TCustomRichViewEdit): Boolean;
  ItemNo, Offs: Integer;
  rve := rve.TopLevelEditor;
  // caret position
  ItemNo := rve.CurItemNo;
  Offs := rve.OffsetInCurItem;
  // is it at the beginning of an item?
  Result := Offs = rve.GetOffsBeforeItem(ItemNo);
  if not Result then
  // is this item at the beginning of paragraph?
  Result := rve.IsParaStart(ItemNo);
  if Result then
  // this is definitely not the first item. maybe it is after a list marker?
  Result := rve.GetItemStyle(ItemNo-1) = rvsListMarker;
If you want to check not only beginnings of paragraphs, but also breaks added by Shift+Enter, change IsParaStart to IsFromNewLine.
If you want to check a screen line (that depends on word wrapping), I can post a code, but it requires using undocumented methods.
