Greetings,
Is there a way to select the text that is in view to work through?
How to select text inview
Re: How to select text inview
Do you want to select all text?
Or do you want to select visible text? If yes, do you want to select lines that are visible only partially?
Greetings Sergey,
Only visible (I select all from time to time but would like to work with visible) partially visible not as important.
Basically would like the user to be able to scroll and certain text would be marked and as it scrolls off screen it is unmarked unlesss they have changed it.
ItemNo1, ItemNo2: Integer;
ItemNo1 := rve.GetFirstItemVisible;
ItemNo2 := rve.GetLastItemVisible;
if ItemNo1 >= 0 then
rve.SetSelectionBounds(ItemNo1, rve.GetOffsBeforeItem(ItemNo1),
ItemNo2, rve.GetOffsAfterItem(ItemNo2));
Thanks Sergey, Perfect, I knew it must be simple.
A small addition I think does it require RVDATA?
rve.RVDATA.GetFirstItemVisible
If I wanted to make it more precise to just the item content in view? Would it be much more?
