1. Can I see a sample of audio encryption?
I want to encrypt with aes, but the video is fine, but the audio is de-encrypted even if I encrypt the stream, and then it goes down.
Even if I send a stream with audio encode parameters it doesn't work.
2. Will android work be past this year?
If android is not supported, I have to stop the project.
Two Questions.
Re: Two Questions.
1. Audio is not encrypted. You can do it yourself in TRVCamSender.OnEncodeAudio and TRVCamReceiver.OnDecodeAudio.
2. No, Android will not be supported in this year.
