[Demo] Convert RTF to DocX (keeping headers and page information)
With TRichView, converting RTF to DocX is simple:
rv.Clear;
rv.LoadRTF(InputFileName);
rv.Format; // necessary if the document contains tables
rv.SaveDocX(OutputFileName, False);
Some property settings are needed to specify loading and saving page information (page size, margins, etc.) and document properties (author, title, etc.)
However, TRichView can store only the main document, without headers and footers. So headers and footers will be lost on conversion.
There are several solutions for this problem.
1. Using TSRichViewEdit from ScaleRichView. ScaleRichView editor can contain both the main document and headers/footers in a single component, so it can load and save them.
2. Create separate TRichView, TRichViewEdit, or TRVReportHelper components for each header and footer. This approach is used in the demo <TRichView Dir>\TRichView\Demos\DelphiUnicode\Assorted\Printing\Headers\
(or identical projects for C++Builder and Lazarus).
This demo projects uses TRichViewEdit for the main document, and for 6 headers and footers.
3. Using TRVReportHelperWithHeaderFooters.
This approach is used in the attached demo.
This project converts RTF to DocX. But with minor modifications, it can convert any of {RTF, RVF} to {RTF, DocX, RVF}.
RTFtoDocX.zip
(1.73 KiB) Downloaded 12094 times
jgkoehn
Re: [Demo] Convert RTF to DocX (keeping headers and page information)
Post by jgkoehn »
Greetings Sergey,
I would be interested in how to bring in the DocX do I need a special component?
Sorry, I do not understand the question.
jgkoehn
Post by jgkoehn »
But with minor modifications, it can convert DocX to RTF,
Does this mean that DocX import is available? If so how does one do it?
DocX import is not yet available (I corrected the text).
It is in development, you can expect it in this autumn.
jgkoehn
Post by jgkoehn »
No pressure just checking on the Docx progress. Any news? Thanks sir!
It will be released in this month.
Zevine
Post by Zevine »
Yes, DocX import is available (for Delphi 2009 and newer). There are LoadDocX and LoadDocXFromStream methods.
Details are here: https://www.trichview.com/forums/viewto ... 885#p38885
