TRVHtmlImporter with Unicode Characters
danielpricecds
Post by danielpricecds »
I am trying to load some html that conatains Unicode characters using the LoadHtml procedure on the TRVHtmlImporter component which seems, when the compilation is unicode enabled, to cast the input parameter to AnsiString which therefore translates the unicode characters to question marks. Any ideas on how I can display unicode characters using the HtmlImporter?
Thanks,
Daniel
RichViewTestForm.zip
(1.53 KiB) Downloaded 958 times
Re: TRVHtmlImporter with Unicode Characters
The parameter of LoadHTML is AnsiString. When you pass Unicode string there, it is converted to ANSI, and Unicode characters are converted to ?.
Use this code:
  RvHtmlImporter1.LoadHtml(UTF8Encode(data));
danielpricecds
Thanks Sergey, that worked!
