Header not printed like in the editor
JMessner
Post by JMessner »
Dear Mister Tkachenko,
i have an issue printing out a Document with a Header containing Text and a graphic.
I doubleclick in the headerarea, insert a grafic (with the InsertGrafic-Action), type some text and print it with the print-action.
The Print-Action is linked to the SRichview-Component.
Instead of the text and the graphic there is only a pagenumber displayed on the printed document...
I use the Scalerichview-Component 7.8.2 and TRichview v16.15
Do you have a solution for me?
Best regards
Re: Header not printed like in the editor
Do you use special ScaleRichView printing actions?
For ScaleRichView, you should not use TrvActionPrint, TrvActionQuickPrint, TrvActionPrintPreview. Instead, use TsrvActionPrint and TsrvActionQuickPrint.
JMessner
Post by JMessner »
Thanks for your fast reply. I will try this.
JMessner
Post by JMessner »
Thanks. This was the solution.
Happy :D
