Paragraph style and ApplyParaStyleConversion
jgkoehn
Post by jgkoehn »
Greetings,
I'm working on a doing some quick format buttons for users and when I use ApplyParaStyleConversion from a demo
Specifically: RichViewEdit.ApplyParaStyleConversion(PARA_SPACE_DEFAULT); Note: GApplyStyle is set to rvs style before calling ApplyParaStyleCovnersion.
See the code below. Also see the attachment. I get a red border and multiline spacing, plus paragraph alignment, etc. when I'm just wanting to change spacing before and after the paragraph. Is it the combination of Actions and this?
procedure TMainForm.rveParaStyleConversion(Sender: TCustomRichViewEdit; rvstyle: TRVStyle;
  StyleNo, UserData: Integer; AppliedToText: Boolean; var NewStyleNo: Integer);
  ParaInfo: TParaInfo;
  ParaInfo := TParaInfo.Create(nil);
    ParaInfo.Assign(GApplyStyle.ParaStyles[StyleNo]);
    case UserData of
      PARA_ALIGNMENT:
        ParaInfo.Alignment := GApplyStyle.ParaStyles[StyleNo].Alignment;
      PARA_INDENTINC:
          ParaInfo.LeftIndent := ParaInfo.LeftIndent + 20;
          if ParaInfo.LeftIndent > 200 then
            ParaInfo.LeftIndent := 200;
      PARA_INDENTDEC:
          ParaInfo.LeftIndent := ParaInfo.LeftIndent - 20;
          if ParaInfo.LeftIndent < 0 then
            ParaInfo.LeftIndent := 0;
      PARA_COLOR: ParaInfo.Background.Color := PParaColor;
      PARA_LINESPACE: ParaInfo.LineSpacing := PParaLineSpaceInt;
      PARA_SPACE_DEFAULT:
           ParaInfo.SpaceBefore:=0;
           ParaInfo.SpaceAfter:= 6;
      // add your code here....
    NewStyleNo := GApplyStyle.FindParaStyle(ParaInfo);
    ParaInfo.Free;
test.rvf
(9.75 KiB) Downloaded 1143 times
Re: Paragraph style and ApplyParaStyleConversion
Is this the exact code?
OnParaStyleConversion does not have rvstyle parameter.
The code looks correct, if GApplyStyle really equals to Sender.Style.
jgkoehn
Post by jgkoehn »
Greetings Sergey,
It is the code, I will need to revisit the rvstyle I think I added that but apparently don't use. I will double check a few things. Thank you
