Error justifying text
Ceprotec
Post by Ceprotec »
English:
At the end of the line when there is a tag, the text does not justify correctly and ends up being a space at the end, it is something that happens rarely, however, it is only solved when I delete and rewrite the tag and the text part ".. mim,"
- Sorry my english. :D
Português:
No final da linha quando há uma tag, o texto não justifica corretamente e acaba ficando um espaço no final, é algo que acontece raramente, porém, só é solucionado no momento em que apago e digito novamente a tag e a parte do texto ".. mim,"
Error example:
Thanks!
Re: Error justifying text
Unlike some other editor, TRichView/ScaleRichView hides no more than one space characters at the place of line break.
If there are several adjacent space character, this effect may occur.
Ceprotec
Post by Ceprotec »
English:
even though there is only one space between the two words?
Português:
mesmo havendo apenas um espaço entre as duas palavras?
This problem must not happen if you have only one space character between words.
If it still exists, please send me this document for testing (as RVF file).
You can attach it to the forum topic, or to a forum private message to me, or send to email richviewgmailcom.
Ceprotec
Post by Ceprotec »
Português:
Desculpe a demora, arquivo logo abaixo:
English:
Sorry for the delay, file below:
texto-erro.rvf
(5.83 KiB) Downloaded 1286 times
