Adding text to video recording
wernerh
Post by wernerh »
I am using the TRVCamRecorder to record videos and just wondering if it's possible to add text to a video, like a caption or timestamp?
Re: Adding text to video recording
Use TRVCamera.OnGetImage event.
The code below adds a timestamp to the bottom right corner:
procedure TForm1.RVCamera1GetImage(Sender: TObject; img: TRVMBitmap);
  bmp: TBitmap;
  S: String;
  Sz: TSize;
  bmp := img.GetBitmap;
  with bmp.Canvas do
    Lock;
      Brush.Style := bsClear;
      Font.PixelsPerInch := 96;
      Font.Name := 'Tahoma';
      Font.Color := clWhite;
      Font.Size := 8;
      S := TimeToStr(Now);
      Sz := TextExtent(S);
      TextOut(bmp.Width - Sz.cx - 2, bmp.Height - Sz.cy - 2, S);
      Unlock;
  img.UpdateData;
Note that this event may be called in a thread context.
If you need to add a static image, like a logo, the recommended way is to prepare it in TRVMBitmap object, and use OnGetImage to draw as img.Draw(X, Y, MyLogoBitmap); You do not need to call img.UpdateData after using this method (if MyLogoBitmap is TRVMBitmap)
