I'm using RVCamera along with RVCamRecorder to record the desktop. The output files gets saved locally in 10 minute increments. CPU usage is high which is understandable but I wasn't wondering if you have any recommendations to improve on this without immediately resorting to hardware upgrades?
CPU usage recording
Re: CPU usage recording
You can lower video quality settings. Probably they are higher than the source quality, that makes no sense.
For example, consider lowing the recorder's VideoFramePerSec and VideoBitrate.
