ActionList problem
jgkoehn
ActionList problem
Post by jgkoehn »
I am sure I am missing something simple.
I needed to move TRichView to a panel. I cut it and several components including ActionList.
When I repasted them on the panel, none of the action buttons work and several of the main menu do not work. I know it must be simple but can you help me out?
If it helps this was in Lazarus
Re: ActionList problem
Maybe buttons lost links to actions?
Do actions have ControlPanel or DefaultControl properties assigned?
jgkoehn
Post by jgkoehn »
Thanks woeking through that. Getting an error before the application opens so we will see. Thanks again
