RVMedia 6 and RTSP - Network problems
Re: RVMedia 6 and RTSP - Network problems
any progress? I tried latest ffmpeg from today and issue persists.
Sorry, we were busy preparing TRichView update.
I'll test your sample tomorrow.
(Ilya already tested it and he was not able to reproduce. Tomorrow I'll try myself)
I made a test project.
Here it is, including exe file and ffmpeg:
https://www.trichview.com/support/files ... chTest.zip
Buttons switch between two video URLs you provided.
I pressed about 50 times. I tried switching between the cameras and restarting the same camera again and again. I found no problems.
I tested in updated version (which will be released as 7.1 soon), but I do not think there is a difference
Does your project use FFmpeg libraries? Is FFmpeg enabled and FFmpeg libraries beside the exe? Without FFmpeg it works. Problem is with FFmpeg.
Yes, this project uses FFmpeg 4.2.1.
Well, look at enhanced example.
https://www.mitec.cz/CamSwitch.zip
I added Indy TCPServer and TCPClient. Client connects to the server at startup and after some camera switches client is disconnected with error 10054 - Connection reset by peer.
It is caused by FFmpeg. It destroys any network application which uses RVCamera and FFmpeg. It is really big problem. It seems FFmpeg closes Winsock for all existing connections in app.
Unfortunately, I do not know how to fix it with FFmpeg.
I can only suggest using GStreamer 0.1. FFmpeg can be turned off by assigning RVCamera1.FFMpegProperty.UseFFMpeg = False.
There is only one difficulty, RVMedia requires correct specification of DeviceType and VideoFormat for GStreamer.
For 'http://150.214.222.100/mjpg/video.mjpg' it is rvdtHTTP, rvvfMJPEG (it can also be played by RVMedia natively, without FFmpeg and GStreamer).
For 'rtmp://semerkandglb.mediatriple.net:1935/semerkandliveedge/semerkand2', I am not sure, currently it does not work stable for me.
Also, I recommend to close IdTCPServer and IdTCPClient in FormClose, otherwise application may hang.
I'm not able to make GStreamer working with any RTSP stream
so it is unusable.
Can you put this issue to FFmpeg bug tracker?
Replaying RTSP is most wanted feature and if it is destroys other application connections then it is serious problem.
Can you focus on this issue, please?
EDIT: I have just tested FFVCL (http://www.delphiffmpeg.com) - components that use FFmpeg libraries for playing rtsp and also http camera streams) and when I modified their Player demo with TCPServer and client, connection is not broken regardless of number of URL changes and replayes. So it seems problem is not inside FFmpeg but your components.
EDIT2: I tried to debug where problem can be and if I replace
with
in MRVFFMPEGObject.CloseVideoFile, problem disappears.
Can you check it?
avformat_close_input(pFormat_context);
avformat_free_context(pFormat_context);
Can you check it?
I hate to say, but I have no idea how to fix it, since the problem seemingly inside FFmpeg
Did you check suggested solution?
It seems you didn't read my post, so once more:
Then I tried to debug where problem can be and if I replace
with
Can you check it?
Can you check it?
It's possible to make this change in RVMedia code too, but I am not sure that it is a correct change.
That's why I want you to check it
Who else can decide if it is correct or not
Any progress?
Sorry, we were busy solving problems in other threads of this forum.
But here, I do not know what I can do. I do not know FFmpeg internals in details, I can rely only to its documentations.
