the size of save files in too big
resilux
Post by resilux »
Yes please, can you provide me an example in Delphi of how to convert images in document to JPEG.
Regards
I updated that topic: http://www.trichview.com/forums/viewtop ... 6749#26749
For converting only metafiles, you can add below
if gr is TJPEGImage then
the following code:
if not (gr is TMetafile) then
Note: when running in Delphi, this code generates exception when attempting to assign TMetafile to TBitmap. But these exceptions are in try..catch, so the code runs correctly.
Now you have access to protected forums, see the protected Announcements forum for new releases.
resilux
Post by resilux »
Thanks Works fine....
I will keep one eye on private fórums for next update.
Regards
