Protected section not set automatically on RTF file loading
filo
Re: Protected section not set automatically on RTF file loading
Post by filo »
At first, thank you for your explanation above.
We are using of quite deeply customized Delphi's TRTFEdit along with our own toolbar (font, bullets, aligning).
My task is to find out a suitable rich text editor which has a zooming capabilities and cover all of our needs. It will be a long way but your TScaleRichView looks like a great solution for this.
Back to "protect" tag:
Sergey Tkachenko wrote: Tue May 09, 2017 1:40 pm If you describe how you want to change text properties of the protected text, I will try to help.
What is available in our RTF Edit for users now:
Switch:
  • "Highlight protected text"
on: all protected text is rendered with specified background color
off: remove background color of protected text
Methods:
  • "Mark selected text as protected" (add caProtected tag and set background color according to the switch mentioned above)
  • "Mark selected text as unprotected" (remove caProtected tag and remove background color)
  • "Jump after next protected text" (Move caret behind the closest protected text - forward direction)
  • "Jump after previous protected text" (Move caret behind the closest protected text - backward direction)
In addition, as a programmer I need to know if character just before and just after the caret is protected.
I'm not familiar with all possibilities of your TRichView yet so I will wait for your proposals.
Thank you!
I'll post these functions tomorrow.
How to highlight protected text.
It's simple, you even do not need to search for protected text. You can check text styles and color them.
To clear highlights, call with Color = clNone.
procedure HighlightProtectedText(RVStyle: TRVStyle; Color: TColor);
  i: Integer;
  for i := 0 to RVStyle.TextStyles.Count - 1 do
    if rvprModifyProtect in RVStyle.TextStyles[i].Protection then
      RVStyle.TextStyles[i].BackColor := Color;
procedure HighlightAllProtectedText(SRV: TSRichViewEdit; Color: TColor);
  i: TSRVHeaderFooterType;
  HighlightProtectedText(SRV.RichViewEdit.Style, Color);
  HighlightProtectedText(SRV.RVHeader.Style, Color);
  HighlightProtectedText(SRV.RVFooter.Style, Color);
  for i := Low(TSRVHeaderFooterType) to High(TSRVHeaderFooterType) do
    HighlightProtectedText(SRV.SubDocuments[i].GetRVStyle, Color);
  if SRV.RVNote <> nil then
    HighlightProtectedText(SRV.RVNote.Style, Color);
  SRV.UpdateBuffer;
How to mark selected text as protected and unprotected.
This example assume that you have ProtectedHighlightColor variable, specifying highlight color for protected text (clNone for no highlighting).
const
  ProtectionOptions = [rvprModifyProtect, rvprDeleteProtect, rvprSticking,
    rvprStyleProtect, rvprDoNotAutoSwitch];
procedure TForm3.ProtectConversion(Sender: TCustomRichViewEdit; StyleNo,
  UserData: Integer; AppliedToText: Boolean; var NewStyleNo: Integer);
  TextStyle: TFontInfo;
  TextStyle := nil;
  case UserData of
    ord(True): // applying protection
      if (ProtectionOptions * Sender.Style.TextStyles[StyleNo].Protection) <>
        ProtectionOptions then
        TextStyle.Assign(Sender.Style.TextStyles[StyleNo]);
        TextStyle.Protection := ProtectionOptions;
        TextStyle.BackColor := ProtectedHighlightColor;
    ord(False): // clearing protection
       [] then
        TextStyle.Protection := [];
        TextStyle.BackColor := clNone;
  if TextStyle <> nil then
    NewStyleNo := Sender.Style.FindTextStyle(TextStyle);
    TextStyle.Free;
procedure TForm3.ApplyProtection(srv: TSRichViewEdit; Protect: Boolean);
  OldStyleConversion: TRVStyleConversionEvent;
  OldStyleConversion := srv.OnStyleConversion;
    srv.OnStyleConversion := ProtectConversion;
    srv.ActiveEditor.ApplyStyleConversion(ord(Protect));
    srv.OnStyleConversion := OldStyleConversion;
Call ApplyProtection(srv, True) to protect, ApplyProtection(srv, False) to remove protection.
The rest of functions will be tomorrow.
filo
Post by filo »
i have already tried your methods in my demo and all of them works like a charm.
Thank you!
filo
Post by filo »
The common font RV actions (bold, italic, strike, ..) reacts to protected as I expect and want, but unfortunately I'm still able to change protected text with changing of style (with TRVStyleTemplateComboBox) or with paragraph actions (ParaBullets, ParaNumbering, ParaList ...).
Maybe there are even more possibilities how to change style which I don't know yet.
From my perspective, the right behavior for changing of protected text is:
  • Disable style changing when paragraph or selected area contains protected text
  • Disable Para* actions if paragraph or selected area contains protected text
Is it possible or am I miss something crucial and there is another way?
Thank you.
I'll check how the protection option affects applying style templates.
Expected: style templates must not be assigned to text items having rvprStyleProtect protection. However, this option does not prevent assigning styles to paragraphs, and styles of paragraphs may contain font properties affecting even protected text. It's by design: protected text is not changed, but its context is changed.
TRichView also supportы paragraph protection options (see http://www.trichview.com/help/idh_tcust ... tions.html)
rvpaoReadOnly - disallowing editing content of this paragraph
rvpaoStyleProtect - disallows changing paragraph properties
rvpaoDoNotWantReturns - disallowing processing Enter (rvpaoReadOnly does not protect from adding new paragraphs by pressing Enter at the beginning or at the end).
But I am not sure that these options must be applied only because paragraphs contain protected text.
I'll check applications of paragraph lists to protected paragraphs.
Expected: no list markers may be inserted between text items having rvprSticking protection. However, existing list markers are not protected from changes.
We uploaded an update, it fixes the problem with caret moving when attempting to insert/paste RVF or press DELETE in the protected text.
About moving to the next/previous occurrence of the protected text.
The simplest way is using functions from RVGoToItem.pas unit, included in RichViewActions:
function GoToNextItemEx(rve: TCustomRichViewEdit; UserData: Pointer;
  Func: TCheckItemFunction; IncludeCurrentItem: Boolean;
  Select: Boolean = False): Boolean;
function GoToPrevItemEx(rve: TCustomRichViewEdit; UserData: Pointer;
As the Func parameter, use:
function IsProtectedText(RVData: TCustomRVData; ItemNo: Integer;
  UserData: Pointer): Boolean;
  StyleNo: Integer;
  StyleNo := RVData.GetItemStyle(ItemNo);
  Result := (StyleNo >= 0) and
    (rvprModifyProtect in RVData.GetRVStyle.TextStyles[StyleNo].Protection)
As for the function returning "protected" state around the caret:
What should it return at the beginning/end of a document? Of a paragraph? Non-text items (pictures, tables) are treated as characters (TRichView can protect them from deletion only)?
filo
Post by filo »
Sergey,
thanks to your latest three posts I'm convinced that my request
is on a too low level and unnecessary.
I see I can use the TCustomRichViewEdit.OnChanging (CanEdit variable) for refusing any user's action.
Can I obtain an information what type of change (text style, para style, font change) is prepared to apply?
If answer is yes, then from my point of view it would be enough to have a method like
"Is there any protected character inside of selected area or in a current paragraph (in case when no text is selected) ?"
With this function I could easily manage changes inside of OnChanging event or maybe there is even more suitable method/event (TRvAction*.ExecuteTarget, TRVStyleTemplateComboBox.DoUpdateSelection ...).
I believe that we are very close to the final solution.
Thank you for your effort, I really appreciate it.
filo
Post by filo »
Sergey, is this information still valid?
Sergey Tkachenko wrote: Fri Aug 17, 2007 2:09 pm In TRichView, there are no end-of-line characters. There is only a flag "this item starts a new line/paragraph".
I'm asking because of your methods GoToNextItemEx, GoToPrevItemEx for jumping after the protected text.
May I suggest a little improvement?
If the protected text is a paragraph or it is located at the end of paragraph, it would be better to immediately move caret to the next item (new line) and not stay at the end of paragraph, because user will have to use enter on arrow key anyway.
As for checking selection for the protection, you can use RichViewEdit.CanDelete method.
Yes, this information (no special end-of-paragraph characters) is still valid.
The function below moves the caret to the beginning of the next paragraph, if it is at the end of a paragraph
(more exactly, paragraph section, breaks may be added by Shift+Enter)
procedure MoveToNextParagraph(rve: TCustomRichViewEdit);
  ItemNo, Offs: Integer;
  rve := rve.TopLevelEditor;
  ItemNo := rve.CurItemNo;
  Offs := rve.OffsetInCurItem;
  if (ItemNo < rve.ItemCount - 1) and (Offs >= rve.GetOffsAfterItem(ItemNo)) and
    rve.IsFromNewLine(ItemNo + 1) then
    inc(ItemNo);
    Offs := rve.GetOffsBeforeItem(ItemNo);
    rve.SetSelectionBounds(ItemNo, Offs, ItemNo, Offs);
filo
Post by filo »
Sergey,
thank you very much, my "custom" jumps have needed some small changes, but together with your code work perfectly just as I want.
I have also tried CanDelete inside of OnChanging event, it works too, but I'm a little bit confused about behavior. Due to lack of source code I can't check a reason, but when I do Ctrl+V from clipboard the OnChanging event is fired more than once (mostly twice, rarely three times). I can reproduce this even with one line simple text, such as
HToolButton := ToolButton;
The similar situation is for Ctrl+X.
Can you explain why is it happened, please?
It's not guaranteed that OnChanging is called only once. Some operations may consist of several smaller operations, each of them testing the editor for possibility to change.
When pasting, the first check occurs at very beginning (if the editor cannot be modified, it makes no sense to get something from the Clipboard). The second check is performed by the insertion procedure.
When cutting, the first check occurs at very beginning (if the editor cannot be modified, the fragment must not be copied). The second check occurs after copying, in the selection deletion procedure.
filo
Post by filo »
OK, understand, thank you.
