List of Hyperlink
Yes, as I said in the previous post, the modified code inserts not all links, so they are mismatched.
The solution: when adding links to the list (in RichView1), do not add the link targets as tags. Use the link index instead.
The code below is for the latest version of TRichView, where tags are strings.
For older versions, remove StrToInt and IntToStr, and exclude rvoTagsArePChars from RichView1.Options.
procedure TFmain.EnumLinksProc(RVData: TCustomRVData; ItemNo: Integer;
  var UserData1: Integer; const UserData2: String;
  var ContinueEnum: Boolean);
var StyleNo: Integer;
  StyleNo := RVData.GetItemStyle(ItemNo);
  if RVData.GetRVStyle.TextStyles[StyleNo].Jump and
     (RVData.GetRVStyle.TextStyles[StyleNo].Color =  clGreen) then
    RichView1.AddNLTag(RVData.GetItemText(ItemNo), RVData.GetItemStyle(ItemNo),
      0, IntToStr(UserData1));
  if RVData.GetItem(ItemNo).GetBoolValueEx(rvbpJump, RVData.GetRVStyle) then
    inc(UserData1);
  ContinueEnum := True;
Now, we need to modify RichView1.OnJump and OnItemHint:
procedure TFmain.RichView1Jump(Sender: TObject; id: Integer);
var RVData: TCustomRVFormattedData;
    ItemNo: Integer;
  RichView1.GetJumpPointLocation(id, RVData, ItemNo);
  id := StrToInt(RVData.GetItemTag(ItemNo));
  // here, id = link index in RichViewEdit
  RichViewEdit1.GetJumpPointLocation(id, RVData, ItemNo);
  RVData := TCustomRVFormattedData(RVData.Edit);
  RVData.SetSelectionBounds(ItemNo, RVData.GetOffsBeforeItem(ItemNo),
    ItemNo, RVData.GetOffsAfterItem(ItemNo));
  RichViewEdit1.SetFocus;
procedure TFmain.RichView1ItemHint(Sender: TCustomRichView;
  RVData: TCustomRVData; ItemNo: Integer; var HintText: String);
var id, LItemNo: Integer;
    LRVData: TCustomRVFormattedData;
  if RVData.GetItem(ItemNo).GetBoolValueEx(rvbpJump, RVData.GetRVStyle) then begin
    RichViewEdit1.GetJumpPointLocation(id, LRVData, LItemNo);
    HintText := LRVData.GetItemTag(LItemNo);
miwan
Post by miwan »
Ok beautiful
that's really what I wanted
problem solved
excuse me for taking too much of your time
thank you very much :D
