Add text with different formats in a cell
leandersantosm
Post by leandersantosm »
Forget the error leaving the form, I fixed it.
Back to the tables, if I create a new table before the table that works fine, this new table will have the error of List index.
What's the stack at the moment of exception?
When the exception occurs, open a call stack window (menu View | Debug Windows | Call Stack), Ctrl+A, then Ctrl+C to select to the Clipboard.
For any case, if you do not use the latest version of TRichView & ScaleRichView, try to update them.
leandersantosm
TList.Error('List index out of bounds (%d)',-60)
TList.Error($41D53C,-60)
TList.Get(-60)
TRVTableRow.Get(???)
TRVTableRows.GetMainCell(3,-60,3,-60)
TSRichViewEdit.checkTable(???,242,387,???)
TSRichViewEdit.MouseMove([],266,282)
TControl.WMMouseMove((512, 0, 266, 282, (266, 282), 0))
TControl.WndProc((512, 0, 18481418, 0, 0, 0, 266, 282, 0, 0))
TWinControl.WndProc((512, 0, 18481418, 0, 0, 0, 266, 282, 0, 0))
TSRichViewEdit.WndProc((512, 0, 18481418, 0, 0, 0, 266, 282, 0, 0))
TWinControl.MainWndProc((512, 0, 18481418, 0, 0, 0, 266, 282, 0, 0))
StdWndProc(396010,512,0,18481418)
TApplication.ProcessMessage((396010, 512, 0, 18481418, 3639300, (755, 581)))
TApplication.HandleMessage
TApplication.Run
ULTRASIS_SGLI
leandersantosm
I'm using RichView 11.0.2 (checked on readme.txt).
This is quite old version. Especially ScaleRichView that was VERY improved since that time. May be the problem is because of a bug in that version of ScaleRichView.
Send me a private message with information about your order(s) (for example, email address. I'll send instructions about updating.
leandersantosm
I guess he was requesting the new version by mail contact yesterday.
The version was already sent to him?
If yes, I will update the components.
Thanks.
I sent TRichView 12 + ScaleRichView 3 (they are free for you). Try them, may be the problem is already fixed.
