[Demo] How to insert YouTube video in the editor
I just tried to reproduce this error in your demo attached to this topic - and this problem exists here too:
Debugger Fault Notification
Project C:\...\TRichView\YouTube\YouTubePlayer.exe faulted with message: 'stack overflow at 0x74f5e2d4'. Process Stopped. Use Step or Run to continue.
OK
Debugger Exception Notification
Project YouTubePlayer.exe raised exception class EInvalidOp with message 'Invalid floating point operation'.
Break Continue Help
Application Error
Exception EAccessViolation in module Flash10o.ocx at 003889B1.
Access violation at address 61AD89B1 in module 'Flash10o.ocx'. Write of address 00000007.
OK
Project YouTubePlayer.exe raised exception class EInvalidOperation with message 'Control 'RichViewEdit1' has no parent window'.
Break Continue Help
I do not think that there can be problems using this component in DB controls.
And I just tested it in TSRichViewEdit - it works (may be scaling is not perfect, but videos are played). However, if you use old version of ScaleRichView, I cannot guarantee that this control works properly. In ScaleRichView 4, we have rewritten processing of inserted controls almost completely.
