[Examples] Count of characters and words
Interesting question.
Characters, paragraphs - yes.
As for word enumeration, as I can see, it is safe too, with one possible problem. It uses TRVWordEnumerator class that was primarily created for spell checking. When called for TRichViewEdit, it prevents its form from closing by assigning its OnCloseQuery event and restoring it after its work.
If several word enumerators will work at the same time in threads, it may happen that the original OnCloseQuery will not be restored.
Calculating paragraph counts in the way like MS Word: empty paragraphs are not taken into account.
Paragraphs are considered empty if they do not contain any of:
- non-empty text items (at least one non-space character);
- bullet or numbering (text);
- non-empty labelitem (label/number/footnote/endnote)
As you can see, paragraph containing only pictures, spaces and tabs are considered empty.
For tables, the count of paragraphs equals to sum of counts of paragraphs in all its cells. The table itself is not counted as a paragraph.
Use:
function GetParaCount(RVData: TCustomRVData): Integer;
var i, r, c, StyleNo: Integer;
table: TRVTableItemInfo;
EmptyPara: Boolean;
ListNo, ListLevel, StartFrom: Integer;
Reset: Boolean;
Result := 0;
EmptyPara := True;
for i := 0 to RVData.ItemCount-1 do begin
if RVData.IsParaStart(i) then begin
if not EmptyPara then
inc(Result);
EmptyPara := True;
StyleNo := RVData.GetItemStyle(i);
if StyleNo=rvsListMarker then begin
RVData.GetListMarkerInfo(i,ListNo, ListLevel, StartFrom, Reset);
if (ListNo>=0) and (ListNo<RVData.GetRVStyle.ListStyles.Count) and
(ListLevel>=0) and (ListLevel<RVData.GetRVStyle.ListStyles[ListNo].Levels.Count) and
RVData.GetRVStyle.ListStyles[ListNo].Levels[ListLevel].UsesFont then
EmptyPara := False
end
else if RVData.GetItem(i) is TRVLabelItemInfo then begin
if Trim(TRVLabelItemInfo(RVData.GetItem(i)).Text)<>'' then
end
else if StyleNo>=0 then begin
if Trim(RVData.GetItemText(i))<>'' then
EmptyPara := False;
end
else if StyleNo=rvsTable then begin
if table.Cells[r,c]<>nil then
inc(Result, GetParaCount(table.Cells[r,c].GetRVData));
inc(Result);
lblParaCount.Caption := IntToStr(GetParaCount(RichViewEdit1.RVData));
Ok, everything works fine here, i can count words/characters/paragraphs but still have some quiestions:
1. When counting document lines globally (including tables) how can I check cursor position globally too? Because RVE.GetCurrentLineCol(line,col); returns only local line number.
2. Using GetLineCount(RVE.RVData); from your example inside RVE.OnCaretMove generates errors. How can I avoid this checking cursor position when it moves?
I want to know global current line number.
How can I check if we got cursor in the current line in this routine:
if RVData.GetItemStyle(RVData.DrawItems[i].ItemNo)=rvsTable then begin
table := TRVTableItemInfo(RVData.GetItem(RVData.DrawItems[i].ItemNo));
inc(Result, GetLineCount(TCustomRVFormattedData(table.Cells[r,c].GetRVData)));
function GetCurrentLine(rve: TCustomRichViewEdit): Integer;
CurRVData: TCustomRVFormattedData;
CurDItemNo: Integer;
CurDOffs: Integer;
function DoGetCurrentLine(RVData: TCustomRVFormattedData; var LineNo: Integer): Boolean;
var i,r,c: Integer;
Result := False;
for i := 0 to RVData.DrawItems.Count-1 do begin
if RVData.DrawItems[i].FromNewLine then
inc(LineNo);
Result := (RVData=CurRVData) and (i=CurDItemNo);
if Result then
if table.Cells[r,c]<>nil then begin
Result := DoGetCurrentLine(TCustomRVFormattedData(table.Cells[r,c].GetRVData), LineNo);
if Result then
CurRVData := rve.TopLevelEditor.RVData;
CurRVData.Item2DrawItem(rve.TopLevelEditor.CurItemNo,
rve.TopLevelEditor.OffsetInCurItem, CurDItemNo, CurDOffs);
Result := 0;
DoGetCurrentLine(rve.RVData, Result);
But the table may contain several lines and in your first example it counts them.
So I can have just one table with 100 lines and get 100 lines result in your line count example. And this is what I need. Just want to know cursor line number according all my 100 lines (now I'm getting 100 lines total and current line is some 3rd line in a table cell, but must include all previous lines)
