Extra Paragraphs, just load / save rtf to rtf/docx?
Re: Extra Paragraphs, just load / save rtf to rtf/docx?
It looks like the problem is in saving tables that have table.BestWidth = 0 (i.e. table width must be calculated from widths of cells).
Widths of cells and borders are saved correctly.
By default, for auto-width tables, the component saves a table width equal to the width of this table in TRichView window, and it may be not exactly precise.
To save such tables as auto-width tables in RTF, assign the global variable from RVTable.pas.
RichViewTableDefaultRTFAutofit := True
In order to make this variable work for DocX as well, change in RVTable.pas function GetTableWidthStr.
The part "if BestWidth = 0 then" must be:
  function GetTableWidthStr: TRVAnsiString;
      if RichViewTableDefaultRTFAutofit or (rvtoRTFAllowAutofit in Options) then
        Result := '<w:tblW w:w="0" w:type="auto"/>'
        Result := RVFormatA('<w:tblW w:w="%d" w:type="dxa"/>',
          [RV_UnitsToTwips(GetWidth(ARVStyle, GetPixelsPerInch, 1), rvuPixels, GetPixelsPerInch)])
    end
This change will be included in the next update.
a.weber
Post by a.weber »
Hello Sergey,
I have tried to the the global variable and changed the code location you showed. This gives another result, but still wrong and different between rtf /docx after loading again in Word. Do I miss something, there are other properties which influence this behavior?
Do you need more informations - to find a solution for this issue?
André
Well, it looks lile this is the reason why this option is not enabled by default.
I'll see what I can do.
Probably, I can save auto-width option only for the table, not for cells.
