[Demo] Sending HTML email. Saving MIME-encoded files.
wray
No background
Post by wray »
first of all, from what i am seeing here, this might be the best support i saw ever. I am still using the demo version of RichView (there were 2 PayPals rejection, i still wonder why since they were PayPal2000, anyway i will use credit card and this is with with paypal :))
Now the issue is like this:
I have to send a HTML email AND i have to write some text over a picture. To do this i figured out i have to set up a background and just andter the text where should be.
The problem is, in Email no background is shown. Everything else is ok, but no background, if i add a picture with AddPictureEx, everything is ok. If i add with BackgroundBitmap, no background is shown in email. The bmp is sent, since the mail had 500k length.
I tried to load a file in Microsoft Word and to play with Wrapping in Format Picture, and i made the picture floating with the text over it. But when i load it in RichView is not floating, is on his own paragraph.
Please advise...
Code is following: (BTW Indy Mime encode works perfectly)
Platform: Borland C++ Builder 5.0, Indy 10
TForm1 *Form1;
TJPEGImage *jp;
TJPEGImage *jp2;
Graphics::TBitmap *bmp;
Graphics::TBitmap *bmp2;
AnsiString GetImageContentType(TGraphic* gr)
if (gr->InheritsFrom(__classid(TJPEGImage)))
return "image/jpeg";
else if (gr->InheritsFrom(__classid(Graphics::TBitmap)))
return "image/bmp";
else if (gr->InheritsFrom(__classid(TIcon)))
return "image/x-icon";
else if (gr->InheritsFrom(__classid(TMetafile)))
return "application/octet-stream";
else if (gr->InheritsFrom(__classid(TPNGObject)))
return "image/png";
else if (gr->InheritsFrom(__classid(TGifImage)))
return "image/gif";
throw Exception("Unknown graphic format");
// THTMLImageItem
__fastcall THTMLImageItem::THTMLImageItem(TCollection* Collection)
: TCollectionItem(Collection)
Stream = new TMemoryStream;
__fastcall THTMLImageItem::~THTMLImageItem()
delete Stream;
// THTMLImagesCollection
__fastcall THTMLImagesCollection::THTMLImagesCollection()
: TCollection(__classid(THTMLImageItem))
THTMLImageItem* __fastcall THTMLImagesCollection::GetItem(int Index)
return (THTMLImageItem*)(TCollection::GetItem(Index));
void __fastcall THTMLImagesCollection::SetItem(int Index, const THTMLImageItem* Value)
TCollection::SetItem(Index, (TCollectionItem*)Value);
__fastcall TForm1::TForm1(TComponent* Owner)
: TForm(Owner)
void __fastcall TForm1::RichViewEdit1SaveImage2(TCustomRichView *Sender,
TGraphic *Graphic, TRVSaveFormat SaveFormat, const AnsiString Path,
const AnsiString ImagePrefix, int &ImageSaveNo, AnsiString &Location,
bool &DoDefault)
if (SaveFormat!=rvsfHTML)
return;
bmp2 = new Graphics::TBitmap;
bmp2->Assign(Graphic);
catch(Exception &E)
bmp2->Width = Graphic->Width;
bmp2->Height = Graphic->Height;
bmp2->Canvas->Draw(0,0,Graphic);
jp2 = new TJPEGImage();
jp2->Assign(bmp2);
delete bmp2;
AnsiString Ext = GraphicExtension((TGraphicClass)(Graphic->ClassType()));
Location = Format("image%d.%s", ARRAYOFCONST((ImageSaveNo, Ext)));
ImageSaveNo++;
THTMLImageItem* Item = (THTMLImageItem*)(HTMLImages->Add());
Graphic->SaveToStream(Item->Stream);
Item->Name = Location;
Item->ContentType = GetImageContentType(Graphic);
Location = "cid:"+Location;
DoDefault = false;
if(jp2 != Graphic) delete jp2;
void __fastcall TForm1::FormCreate(TObject *Sender)
jp = new TJPEGImage();
bmp = new Graphics::TBitmap;
HTMLImages = new THTMLImagesCollection;
void __fastcall TForm1::Gen_actClick(TObject *Sender)
AnsiString Target = "www.xxxxxxxxx.com";
bmp->Assign(Image2->Picture->Graphic);
RichViewEdit1->BackgroundBitmap = bmp;
RichViewEdit1->BackgroundStyle = bsCentered;
RichViewEdit1->AddBreakEx(4, rvbsLine, clBlue);
RichViewEdit1->AddNL("Activation code", 1, 1);
RichViewEdit1->AddNL("", 1, 1);
RichViewEdit1->AddNL("",0,0);
RichViewEdit1->AddNL("",4,0);
RichViewEdit1->AddNL(" ", 0, 0);
// RichViewEdit1->AddBulletEx("", 0, ImageList1, -1);
RichViewEdit1->Add(" Your activation code is: ", 2);
RichViewEdit1->Add("12345678",0);
// RichViewEdit1->AddBulletEx("", 1, ImageList1, -1);
RichViewEdit1->AddNLTag(Target,3,1, (int)StrNew(Target.c_str()));
RichViewEdit1->Format();
void __fastcall TForm1::SendClick(TObject *Sender)
AnsiString Result;
AnsiString s,s2;
WideString ws;
HTMLImages->Clear();
//saving text
TMemoryStream* Stream2 = new TMemoryStream();
RichViewEdit1->SaveTextToStreamW("", Stream2, 80, false, false);
Stream2->Seek(0,0);
ws.SetLength(Stream2->Size /2);
if(Stream2->Size != 0)
Stream2->ReadBuffer(ws,Stream2->Size);
s2 = IdEncoderMIME1->EncodeString(IdEncoderMIME1->ClassType(),Utf8Encode(ws));
delete Stream2;
//saving HTML
TStringStream* Stream = new TStringStream("");
RichViewEdit1->SaveHTMLToStreamEx(Stream, "", "Web Archive Demo", "", "", "", "",TRVSaveOptions() << rvsoUseCheckpointsNames << rvsoUTF8);
s = IdEncoderMIME1->EncodeString(IdEncoderMIME1->ClassType(),Stream->DataString); //MimeEncodeString(Stream->DataString);
delete Stream;
// now s contains HTML file without images, base64-encoded. saving it in MIME
AnsiString BOUNDARY_TEXT_AND_HTML = "----=_TEXT_AND_HTML_BOUNDARY_";
AnsiString BOUNDARY_MESSAGE_AND_PICTURES = "----=_MESSAGE_AND_PICS_BOUNDARY_";
AnsiString BOUNDARY_MAIN_AND_ATTACHMENTS = "----=_MAIN_AND_ATTACHMENTS_BOUNDARY_";
Result = "This is a multi-part message in MIME format.\n\n";
if(HTMLImages->Count > 0)
Result += "--" + BOUNDARY_MESSAGE_AND_PICTURES+"\n";
Result += "Content-Type: multipart/alternative;\n\tboundary=\"" + BOUNDARY_TEXT_AND_HTML +"\"\n\n--" +BOUNDARY_TEXT_AND_HTML + "\n";
Result += "--" + BOUNDARY_TEXT_AND_HTML + "\n";
Result += "Content-Type: text/plain;\n\tcharset=\"utf-8\"\nContent-Transfer-Encoding: base64\n\n";
Result += s2;
Result += "\n\n--" + BOUNDARY_TEXT_AND_HTML + "\n";
Result += "Content-Type: text/html;\n\tcharset=\"utf-8\"\nContent-Transfer-Encoding: base64\n\n";
Result += s;
Result += "\n\n--" + BOUNDARY_TEXT_AND_HTML +"--\n";
// saving images
for (int i=0; i<HTMLImages->Count; i++)
s2 = "\n--" + BOUNDARY_MESSAGE_AND_PICTURES + "\n";
s.SetLength(HTMLImages->Items->Stream->Size);
HTMLImages->Items->Stream->Position = 0;
HTMLImages->Items->Stream->ReadBuffer(s.c_str(), s.Length());
s = IdEncoderMIME1->EncodeString(IdEncoderMIME1->ClassType(),s);
s2 += "Content-Type: "+HTMLImages->Items->ContentType +";\n\tname=\"" + HTMLImages->Items->Name +"\"\nContent-Transfer-Encoding: base64\nContent-ID: <" + HTMLImages->Items->Name +">\n\n" + s + "\n";
Result += s2;
Result += "\n--" + BOUNDARY_MESSAGE_AND_PICTURES + "--\n";
IdMessage1->Clear();
IdMessage1->Date = Now();
IdMessage1->Subject = "[xxxxxxxxxxx] Activation Code !";
IdMessage1->Recipients->Add();
IdMessage1->Recipients->Items[0]->Address = "[email protected]";
IdMessage1->Sender->Address = "[email protected]";
IdMessage1->From->Name = "xxxxxxx Server";
IdMessage1->From->Address = "[email protected]";
IdMessage1->Body->Text = Result;
IdMessage1->ExtraHeaders->Add("MIME-Version: 1.0");
IdMessage1->ExtraHeaders->Add("Content-Type: multipart/related;");
IdMessage1->ExtraHeaders->Add("\ttype=\"multipart/alternative\";");
IdMessage1->ExtraHeaders->Add("\tboundary=\"" + BOUNDARY_MESSAGE_AND_PICTURES +"\"");
IdMessage1->ExtraHeaders->Add("Content-Type: multipart/alternative;");
IdMessage1->ExtraHeaders->Add("\tboundary=\"" + BOUNDARY_TEXT_AND_HTML + "\"");
Form1->IdSMTP1->Host = "xxxxxx.ro";
Form1->IdSMTP1->Port = 25;
Form1->IdSMTP1->Username = "[email protected]";
Form1->IdSMTP1->Password = "xxxxxxx";
Form1->IdSMTP1->ConnectTimeout = 2000;
Form1->IdSMTP1->Connect();
Form1->IdSMTP1->Authenticate();
Form1->IdSMTP1->Send(IdMessage1);
Form1->IdSMTP1->Disconnect(true);
Thank you in advance
Vlad
Please send me a project reproducing the problem. I'll try to see what's wrong.
wray
Post by wray »
Ok, i will send a PM.
You can test with your posted code, but translate it from delphi to c++, for me the result was the same, no background in mail.
Please test with a YAHOO mail, this is what i used, not outlook or other pop3 software.
Regards
May be yahoo web interface does not support background images in e-mails?
wray
Post by wray »
Well, yes is very possible...
I just started using RichView and i do not know the advanced stuff, and i do not know how the HTML is formated, but if it used CSS styles, then i am almost positive the web interfaces blocks the backgroud...
http://www.xavierfrenette.com/articles/ ... -hotmail-1
Here are some details about what is allowed and what is not allowed on wide used web mails like Gmail, Yahoo and Hotmail
One thing is sure, on Gmail, the background is attached as picture but not displayed as background... Maybe is the case for Yahoo too.
Tell me if there is any other possibility to display text over a picture ?
If not, i will use headers and footers and hell with background :)
Regards
Vlad
You can use SaveHTMLToStream instead of SaveHTMLToStreamEx to save HTML without CSS.
And you can insert text in table with background picture (background picture can be assigned to the table itself or to table cell)
wray
Post by wray »
I tried that too, it just seems webmails like yahoo HATE backgrounds...
Tried cell background and table background - same result :(
BUT after final try i listened to you and saved HTML without CSS and IT WORKS !!!
THANKS - verified solution - cell background and saved without CSS
Payment is ok now, i just wait for key now, see you soon on members forum ;)
Regards
Vlad
dmitry_oz
load email in MIME format into TichViewEdit
Post by dmitry_oz »
do you have DEMO for this?
Demo for that?
http://www.trichview.com/support/files/mime.zip contains demos:
- saving EML/MHT file (HTML + images), for Delphi and for C++
- sending HTML email using Indy components (plain text + HTML + images + attached files), for Delphi
dmitry_oz
Post by dmitry_oz »
Sorry, I was not clear enough.
I was asking for DEMO on loading email into RichView.
My understanding is if email has bundled rtf/txt/html it should be possible to do so
Cheers,
Dmitry
Sorry, no.
You should use any component that can disassemble mime file into separate parts-files, then use RvHtmlImporter to load HTML.
Note that HTML email has a nested structure like this:
<(text {HTML, image1, image2, ...}) file1, file2...>
If there are no files, the level () does not present.
If there are no images, the level {} does not present.
nikivanov
Post by nikivanov »
Sergey, could you create a similar example for Clever Internet Suite 7? I would not want to use the The Delphi Inspiration's DIMime unit. Perhaps it can be replaced by Mail Message or Encoder component from CIS 7?
nikivanov, a demo is coming soon
nikivanov
Post by nikivanov »
Sergey, thank you very much, I'll wait ...
vario_sts
Hyperlinks
Post by vario_sts »
Hi, i´ve downloaded that indy demo and i´ve put some hyperlinks into the richviewedit and than i´ve send it via html mail, but the hyperlink does not work, it´s only blue and underlined...
What must I change, to use it correctly?
