TRichView in Android
jgkoehn
Re: TRichView in Android
Post by jgkoehn »
So all that needed changed to get it working in Delphi 10.4 Community Edition (Though Error: Abstract Error is still there inside the TRichViewEdit component on the Android device though the other RichViewEdit renders correctly otherwise so far at least with text.)
File fmxRVEdit
1. In the first uses include System.Types in {$IFDEF FIREMONKEY}
2. In the second occurrence of implementation uses comment out System.Types around line 1310.
File ? can't remember
1. In another file There was a {$ENDIF} before an else that Delphi didn't like but I can't remember the file now. I moved it after the else
Lastly
In the android app don't set the style of the RichViewEdit in the design interface or in the FormCreate.
You can do it later via a button or something which is not ideal so I am still trying to understand what to do.
Perhaps this will give some ideas on getting going.
I am sure Sergey can explain better and has some ideas when he gets time.
rizarefaldi
Post by rizarefaldi »
Definitely not in 2021?
I am currently working in MacOS version and it has the same problems.
So, very probably, when MacOS version will be released (in this October), it will also work on Android (but I cannot guarantee).
jgkoehn
Post by jgkoehn »
Sergey,
I see you released MacOS very nice work sir. Did that help with Android? I am trying out 20.0.1 of TRichView.
When in Android I see it can't find the FMX files. I am seeing if I can work around it. Thanks for all your hard work sir.
jgkoehn
Post by jgkoehn »
With Delphi 11 it is much quicker to get something to work with. I see that RichView works pretty much right away. TRichViewEdit has some problems when trying to assign the RVStyle.
There seems to be some selection settings that I need to adjust when I try to scroll the app with my finger. The app is having troubles between deciding if I want select or scroll. Probably just a setting. This is getting closer Sergey. Thank you!
dirlisroy
Post by dirlisroy »
I set the RVStyle using a button instead of on FormCreate. At least now in RichViewEdit1 I get "Error: Abscract Error" get-shareit.com get-vidmateapk.com
Android is not supported yet, only Windows and macOS.
I planned to add Android support in this winter, but unfortunately I have to delay major releases.
Current plans:
- maintenance TRichView release with minor new features at this weekend or the beginning of the next week;
- RVMedia release (almost ready, just sound for Linux needs to be fixed)
- TRichView for Android.
jgkoehn
Post by jgkoehn »
Greetings Sergey, When TRichView for Android needs testing I would be interested. I have a project I would like to use it on. However, no pressure.
