TSRVScrollBar.IncButtonWidth
Specifies width of the button for scrolling to the end.
property IncButtonWidth: TRVPixel96Length;
If value of this property is 0, a system default value is used. Values less than 5 are treated as  5.
This value is used only in a skin mode.
This value is measured in pixels at 96 pixels per inch; the actual size scaled according to the current screen pixel density.
Default value
0
