TSRVPageScroll.Columns
Specifies the number of columns (if ScrollType=psstVertical) or rows (if ScrollType=psstHorizontal),
property Columns: Integer;
For example, if SRichViewEdit.PageCount=5 and Columns=2, thumbnails are displayed in the order shown below.
If ScrollType=psstVertical:
1 2
3 4
5
If ScrollType=psstHorizontal:
1 3 5
2 4
A distance between columns is defined in PageBreakWidth, a distance between rows is defined in PageBreakHeight.
Default value:
1
