TSRVCloseButton.IndentX
Specifies the horizontal indent added to the button position.
property IndentX: TRVPixel96Length;
If HorizonalAlign=srvthaRight, the button is shifted to the left by this value. Otherwise, it is shifted to the right.
This value is measured in pixels at 96 pixels per inch; the actual size scaled according to the current screen pixel density.
Default value:
3
