TSRichViewEdit.GetTableIconRVData
The function returns a document containing the table for which the "icon" (rectangle in the top left corner) is displayed.
function GetTableIconRVData: TCustomRVFormattedData;
The returned value may be RichViewEdit.RVData, table cell, or cell inplace editor's RVData.
This method can be used in OnTableIconClick event.
If a table icon is not displayed, the function returns nil.
Table icon is displayed when the user moves the mouse pointer above the table, if ViewProperty.UseTableIcons=True.
