TRVShapeItemInfo.Color, Opacity
Fill color and opacity for the shape.
Color: TRVColor;
Opacity: TRVOpacity;
If GradientType = rvgtNone, the shape is filled with this color. Otherwise, this color is used as an ending gradient color (the starting color is StartColor).
Opacity must be in range from 0 (transparent) to 100000 (opaque).
VCL and LCL: Gradient and opacity are used only if shapes are drawn using GDI+ (in Delphi XE2+ and optionally in Lazarus).
Use TRichViewEdit.SetCurrentItemExtraIntPropertyEx to change value of these properties as an editing operation (rveipcShapeColor, rveipcShapeOpacity).
Default values
Color: $C68E63 for VCL and LCL; $FF638EC6 for FMX
Opacity: 100000 (i.e. 100%)
