TRVRowGenerationCustomRule.FirstRow, RowCount
The properties defining a range of rows of the report table to apply this rule.
property FirstRow: Integer;
property RowCount: Integer;
The rule is applied to the row range FirstRow..FirstRow+RowCount-1. Indexes of rows are counted from 0.
If this is a nested rule, FirstRow is added to the position of its parent rule.
The rule is applied only if the range of rows is correct, i.e.:
for a root rule, this range is inside 0..Table.RowCount-1;
for a nested rule, this range is inside 0..RowCount-1 of the parent rule;
table rows belonging to this range do not overlap with rows below and above (because of a vertical cell merging)
this range does not intersect with ranges of rules having lower indexes in the collection.
The row indexes are counted in the original table in a report template (not in a table produced by an application of previous rules).
Default values:
FirstRow = 0
RowCount = 1
