TRVReportQueryProcessor.GetRecordCount
Returns the count of records returned for a data query.
function GetRecordCount: Integer;
A query processor is not necessary supports quick calculation of record counts. So it may return MaxInt, if it has a non-zero count of records. In this case, a report generator will enumerate records until MoveToNextRecord returns False.
You rarely need to use this method. Usually, query processors are used to get field values from the current record.
